Curious about the temperture...
Old Aug 10, 2007 | 12:33 PM
runner140*'s Avatar
runner140*
Default Curious about the temperture...
I'm curious, about what is the under hood temperture on a 25 mile drive at over 90 degrees of outside templ.
I'll be using a digital thermometer with a 10' wire extension sensor. I'll put the senson near the alternator and monitor it from my dash.
I'll get back to this post with the results when I get home after 6:00pm.
Old Aug 10, 2007 | 05:02 PM
runner140*'s Avatar
runner140*
The underhood tempertures on a 25 mile drive at 90+ degrees tonight was 156 degrees and it stayed there for the last ten miles.
Old Aug 10, 2007 | 05:13 PM
Aardwolf's Avatar
Aardwolf
Good to know!
I'd be curious to check mine with all the hood mods. Where did you get the tool?
Old Aug 10, 2007 | 05:51 PM
Mekanic's Avatar
Mekanic
any mods on that? Louvers? coated headers, drilled out seal .. etc?
Old Aug 11, 2007 | 11:34 AM
Hotred94's Avatar
Hotred94
I've learned there are a lot of variations in temp under the hood depending on where you put the sensor and mods to airflow. 156* sounds about right depending on how high the sensor is located. I've been logging about 150* near the alternator (front, outside). Up near the nose I get 130ish.
To Curious about the temperture...
