Heater Hose Question
Old Aug 11, 2007 | 11:56 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default Heater Hose Question
1990 L98 w/ oil cooler. I am in the process of replacing a leaky water pump, and I wanted to replace the heater hoses. The hose that runs from the expansion tank to the wp seems to have a really large (1") size coming out, but then goes down to 3/4" were it splits to run to the oil cooler. I can see that this is a formed hose, but is it still available? If not, what did you use to replace it? I thought I could just use 3/4", because thats what "tee" fitting is. any ideas/suggestions?
Thanks in advance.
Damm, wrong section, this should be the Tech section.
Old Aug 11, 2007 | 12:22 PM
Muffin's Avatar
Muffin
It has been three years but I got a set of those hoses for my 85 from my local dealer. I suggest you try there.
Old Aug 11, 2007 | 04:31 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Closed per op's request.
To Heater Hose Question
