Wiring Harness
Old Aug 12, 2007 | 10:08 AM
navet72's Avatar
navet72
Default Wiring Harness
Am in the process of working on my 76 and after looking at the current wiring mess I'm contemplating just replacing the whole disater with a new harness. Any thoughts on how big of a PIA this would be and any recommentations about brands to look it? I'm looking at KISS brand now but any thoughts or opinions would be extremely helpful.
Old Aug 12, 2007 | 01:30 PM
VtVette's Avatar
VtVette
I would post in the C3 section you will get a much better response.
I do have experience with C3s though. I've rewired the entire dash in one. Not hard at all but you do need to remove the center console, dash and a lot of trim. Not hard just time consuming. If you are not very familiar with electrical work I would go with a good used OE harness from a '76. It will be plug and play. Aftermarket harnesses can be a real pain if you're not familiar or comfortable with electrical work. Many times connectors need to be installed/changed and a lot of times there will be a fair number of wires you won't need, or will need to add. It can all add up to a fair bit of confusion.
Old Aug 12, 2007 | 09:00 PM
navet72's Avatar
navet72
My apologies I thought I had posted this to the c3 forum!Thanks for the info though.
Old Aug 12, 2007 | 09:48 PM
LD85's Avatar
LD85
easy
www.jimsperformance.com
he will rebuild with new connectors, wiring and insulation & debug or makle a new complete a harness
rework & debug is @ $150
To Wiring Harness
