Ok I recently just purchased the Chiltons Corvette Repair manual, and I also have the Haynes manual to, now heres the problem I ran the codes for my car and it showed me a H72. I looked it up in the Haynes manual and the chiltons manual and it says it is GEAR SELECTOR SWITCH CIRCUIT.I looked all through both manuals and I cant seem to find where this gear selector switch circuit is??? It dont say where it is located at??? Does anyone know where it would be located Im having a very hard time with this I looked over the chiltons manual like 3 times and cant seem to find nothing.If anyone knows anything about this please help thanks alot Tony
Beats me Tony, but I'd start in your console. Start taking that thing apart or just narrow your search down in that part of the book. Sucker's gotta be in there somewhere. Good luck.
I mean its buggn me to death I spent 2hrs reading the chiltons manual and nothing, geez this is driving me crazy
DTC 72 is Vehicle speed sensor loss.
The VSS supplies re: axel ratios & converts that info into a squqre wave??, whatever that is, for use by the speedo, cruise control & central control module.
If it's a history code & not current, (you shud check again to see if it's current, ) it may have cleared when the ignition was cycled. Get an FSM...it saves a ton of frustration.
The FSM will pay for itself with the first problem. Todays cars are fairly easy to fix with the FSM, almost impossible without. They run $50 - $125 0n EBAY, and even if you take your car to a mechanic will pay for itself. That Chiltons manual should come on a roll.
HMMMMS No I dont have an after market radio I just have the factory speakers in the car havnt changed them. I have a Fsm for the car also and looked over it too and nothing its like my car sometimes will shift properly and then it will get to about 4k rpm then shift without me flooring the gas.Then sometimes it will shift smooth like a perfect shift, what is going on any ideas ??? Anybody have this problem with their car I changed the tranny fluid and filter also.
