CAGS Question
Old Aug 15, 2007 | 09:54 AM
ineVETTEable's Avatar
ineVETTEable
Default CAGS Question
Can anyone explain the advantages and disadvantages of disconnecting the CAGS?
Thanks in advance
Old Aug 15, 2007 | 09:59 AM
VetteSlave's Avatar
VetteSlave
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Hello- How's about being able to shift into second when you want to, at the right time? This is the single most user friendly thing that you can do for your car! Disadvantages? I can't think of a single one. I more than highly recommend it!
Old Aug 15, 2007 | 10:02 AM
ineVETTEable
so if you leave it in drive it will shift thru the gears or you can manually shift gears?
Old Aug 15, 2007 | 10:10 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Does someone have the manual and the automatic transmissions confused?
The CAGS is on 6-speed gearboxes only.
Larry
code5coupe
__________
not easily impressed....
Old Aug 15, 2007 | 10:43 AM
ineVETTEable
:o
never mind
Old Aug 15, 2007 | 11:33 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Thanks in advance
Advantage - doesn't **** you off when you want to goto 2nd and it forces you to 4th
Disadvantage - none.
Depending on your car, you can just disconnect the connector. Some of the years throw a code. My 89 never had any code issues. If you get a code, you can have it programmed out or get the "bypass module" that plugs into the connector.
Old Aug 15, 2007 | 11:35 AM
GIJoe's Avatar
GIJoe
DOH! I see this is for an auto...
It pays to finish reading ALL the replies before responding...
Old Aug 15, 2007 | 11:46 AM
LouisvilleLT4's Avatar
LouisvilleLT4
Hahahahaha, oh man.
By the way, if you had the six-speed, you wouldn't have to ask why you would want to unplug the CAGS, trust me. It's that bad.
Old Aug 15, 2007 | 11:48 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Originally Posted by LouisvilleLT4
Hahahahaha, oh man.
Few things are more agravating.
Old Aug 15, 2007 | 12:16 PM
ineVETTEable
Dealing with a bout of intracranial gas
Old Aug 15, 2007 | 01:44 PM
GIJoe's Avatar
GIJoe
Hahahahaha, oh man.
hah yeah you ain't kidding.
When I bought my car way back when, I think the CAGS was already disconnected.
After I rebuilt my motor a few years back, we must have reconnected it not knowing what it was.. so all of the sudden i can't shift into 2nd anymore and I couldn't figure out why until I stumbled into a CAGS thread and learned about it. I unplugged it again and was back to happier shifting
To CAGS Question
