New Question!
Old Aug 15, 2007 | 11:01 AM
aquablue96's Avatar
aquablue96
Default New Question!
Got the car back and she rides great, no squeaks, creaks etc. No however the digital dash is flashing "sys". I do not have an owners manual, does anyone know what the problem might be? All guages reading great.
Old Aug 15, 2007 | 11:35 AM
clf93lt1's Avatar
clf93lt1
Check the battery.
Old Aug 15, 2007 | 11:36 AM
dclafleur's Avatar
dclafleur
Congrats on getting it back together, I know it has been distressing you for a while. I don't know much about the flashing sys light hopefully it is something simple.
Old Aug 15, 2007 | 11:39 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It means you have a control module error, ABS, or the like. Not a major problem, but one you should have checked. You might try disconnecting the battery for 5 minutes and see if it goes away, and have it checked if it comes back. It may have been tripped when the car was in the shop.
Old Aug 15, 2007 | 11:41 AM
DisasterDave's Avatar
DisasterDave
Yeah, someone in here should have an answer for you pretty quick. Congrats on keepin your head and working through your peoblem. You get an A in C4 Troubleshooting 101.
DD
Old Aug 15, 2007 | 11:46 AM
aquablue96's Avatar
aquablue96
Thanks for the praise. I am trying to keep my head for sure. Wondering if it could be because the door ajar button was leaving the lights on and battery was almost dead when i picked it up? It started but you coudl tell it was low? I will try disconnecting it tonight and thanks again.
Old Aug 15, 2007 | 02:37 PM
89 Bob L's Avatar
89 Bob L
Disconnecting the battery for a minute or two should correct the problem. If not pull the codes.
Old Aug 15, 2007 | 02:46 PM
aquablue96's Avatar
aquablue96
Went and had the codes ran, there are none (YEAH) and seems that was enough to turn it off.
Old Aug 15, 2007 | 04:04 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I believe you have hit the nail on the head. A low or discharged battery will cause the SYS to flash.
Old Aug 15, 2007 | 04:05 PM
aquablue96's Avatar
aquablue96
Woo HOO! I am starting to sound like I know what i am talking about
Old Aug 15, 2007 | 05:56 PM
aminnich's Avatar
aminnich
Now that you mention it, What R U talking about? Got it back from whom or what?
Old Aug 15, 2007 | 05:58 PM
aquablue96's Avatar
aquablue96
Sorry, if you were not following my saga. I just got it back from a mechanic/body shop.
To New Question!
