Just a quick shout out to see if anyone else's C-4 has a windshield monted rearview mirror that vibrates at speed. Mine appears tight at the base. If you've had this dilemma, have you been able to fix the annoyance, or do you just deal with the distortion? I would certainly like to check for cops when I'm in a hurry.........
Mike
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Mine vibrates, also. I've tried several things to reduce the vibration; the best step was to loosen the screw!
I tried adding some lead weight to decrease it's harmonic frequency, but that was unsatisfactory. Loosening the screw certainly didn't stop the vibration, but it diminished it somewhat....
Mike
...mine is tight all the way around...i had a vibration and later, blew a wheel bearing...if all is tight, could be bent rim, threw a wheel weight, worn suspension parts, a tire issue, etc......afetr i did all my bearings and half shaft u-joints, mirror is fine....
