Different A/C question
Old Aug 17, 2007 | 10:59 PM
firemanjim's Avatar
firemanjim
Default Different A/C question
Ok, i hope someone has seen this before....my A/C compressor runs all the time, even when the climate control is off??? Please don't tell me the control unit is bad, cause if it is I'll just have too go without A/C. Money's too tight to fix right now especially with school starting back up and having to buy clothes for two kids. Any help would be appriciated.... Thanks Jim
Old Aug 17, 2007 | 11:21 PM
InHot's Avatar
InHot
Sounds like the clutch relay is stuck closed.
Old Aug 17, 2007 | 11:27 PM
93*Corvette's Avatar
93*Corvette
Sounds to me like a low pressure switch is shorted out. When loading freon in a car you short the low pressure to force the compressor to run constantly....
Old Aug 17, 2007 | 11:41 PM
firemanjim's Avatar
firemanjim
Thats quite possible. Now where's the clutch relay located...
Old Aug 18, 2007 | 09:29 AM
JackDidley's Avatar
JackDidley
I am betting on the control module. Its in the evaporator box at the top. All the wires plug into it. easy to fix.
Old Aug 18, 2007 | 11:12 AM
InHot's Avatar
InHot
On my 96 for the electronic control, it is on the rear of the right front wheel well.
Do you have a FSM?
Old Aug 18, 2007 | 11:21 AM
Da Mail Man's Avatar
Da Mail Man
....don't think so! ..the compressor shouldn't run without power going to it through the relay...the lp switch is to prevent "freeze-ups" and running with insufficient charge!....while it is true that the lp switch can be shorted to make the compressor turn on, shorting it wouldn't do anything unless there was power going through it first...it can also be intentionally shorted to "draw" refrigerant when recharging system from scratch...
Old Aug 18, 2007 | 12:29 PM
InHot's Avatar
InHot
Your car has a Cycling Clutch Orifice Tube (CCOT) refrigeration system designed to cycle a compressor on and off to maintain desired cooling and to prevent evaporator freeze.
Control of the refrigeration cycle (on and off), is done with a switch which senses low side pressure as an indicator of evaporator temp.
This is from my 96 but your's should be similiar. The Hvac programmer sends a request for A/C to the PCM via the press cycling switch by grounding this circuit. This NO switch cycles on and off and must be jumped to refill an empty system. If the switch is closed, the PCM grounds the clutch relay through term 86. The relay then closes providing 12V is avail at 85 and 87 thru the A/C clutch fuse.
The feedback to the PCM via CKT 59 tell the PCM that the clutch is engaged and is used to maintain idle speed.
Disconnect 86 and the clutch should disengage. If it does then check the A/C request circuit for a short. If not. the relay is stuck closed.
Good luck!
To Different A/C question
