Exhaust Question?!
Old Aug 19, 2007 | 03:11 PM
ARMAN72's Avatar
ARMAN72
Default Exhaust Question?!
Hey guys I have a 93 with stock exhaust which to me doesnt sounds as good as i think it should.. Please tell me what kind of exhaust system most of you are running? I like the stock exhaust tips look! Thanks in advance!
Old Aug 19, 2007 | 03:19 PM
vettowner1994's Avatar
vettowner1994
I put on Walker high performance, flow through mufflers on mine. Not to expensive, a bit louder then stock but not overkill on noise. They have the stock OEM tips on them too which I like the looks of the best. Depends on how much you want to spend which in my case and as much as I drive mine, that was enough.
Old Aug 19, 2007 | 03:21 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
There are many brands of aftermarket mufflers; Borla, Corsa, Magnaflow, etc. Ask ten guys and you'll get eleven answers. One of the best sounding, IMO, is muffler eliminators.
The best way to pick one for you is to go to a Corvette meet and listen to the various exhausts. When you hear one you like ask the owner what it is and if he's pleased with it.
ARMAN72's Avatar
ARMAN72
I guess I should have put I dont want to spend BIG BUCKS on it, i would rather put that money some where else in the car!
Old Aug 19, 2007 | 03:58 PM
aminnich's Avatar
aminnich
Have your local muffler shop cut off the mufflers and weld on the tips you like. Best way for good sound at cheap price. Save the old mufflers in case you change you rmind later.
To Exhaust Question?!
