My starter died today. I know its not the battery, because its brand new and when jumped it just doesn't want to crank. It clicks, but nothing else. Anyone have any tips on replacing it?
First thing, check for hidden corrosion in the line to the starter. It may not be the starter but a weakened power flow. I've had this happen on my '88.......
If the battery to starter cables are the originals I'd replace them first.
They can corrode on the inside and the ends look OK.
I know this sounds crazy but it happened to me. I replaced both positive and negative cables and it started fine then.
My starter is the original (knock on wood!) with 100K + on my car.
If it does end up being your starter I'd take it too a good local electrical shop and have yours rebuilt or buy a new GM/Delco from thepartsladi on eBay or elsewhere.
I've heard bad stories about the cheap rebuilt ones from Auto Zone, O'Rilley, etc...
On that red positive line, pull it back off the battery and push that bolt out of the plastic housing and make sure that it's clean and making good contact in the fitting
Take a voltage reading at the feed wire to the starter solenoid while someone tries to start the car. It's the small wire. If you're not getting fully battery voltage there, trace the wire back to the ignition switch. Then jump direct battery voltage to it and see if it now spins.
If there is full battery voltage going to it, then yes there is something going on with the starter. Try smacking it some with a hammer and see if anything changes.
I'm having this same issue on my other car. Even though the battery is fully charged, I only get about 8 volts at the starter solenoid feed wire. So the starter only clicks but won't crank the car. If I apply a direct uninterrupted 12 volts from the battery, the stater spins each and every time. On my car I'm thinking a bad ignition switch, or a bad connection somewhere along the feed wire.
If it's a starter problem, remove it and open the case. The copper contact on the solenoid plunger and the copper battery lug terminal usually pit and make poor contact.
Here's a link.
Scroll down and there are pictures and the procedure on how to replace the contacts.
If it's a starter problem, remove it and open the case. The copper contact on the solenoid plunger and the copper battery lug terminal usually pit and make poor contact. Here's a link with some pictures and procedures of how to replace the contacts.
Cessnadriver, am guessing you are not overly auto repair inclined. If so all the proceeding posts, though correct, are beyond what you are inclined tackle. If so your first, and most expensive, option would be to have the car towed to a shop and the starter repaired/replaced. Second would be to DIY. Not hard but can be a little tricky getting the starter out. Has to clear tranny lines and exhaust pipes. Haynes or Chilton will tell you how. If you decide to replace I would suggest a mini hi-torque starter. Will run you about $150.00 but will last a long time.
This exact thing just happened to my 94. I replaced the starter- problem solved. Total job time took about 25 minutes with a phone call interuption.
Thanks everyone for the help. With my dad and a former Corvette mechanics supervision, I cleaned the corossion off of the cables and checked the battery. They both said it is the starter. Just picked up a new starter today after school. My dad is going to help me jack it up so I can put the new one in. I cant wait to get it back on the road again!
