My turn for problem
Old Aug 25, 2007 | 07:04 PM
jabez's Avatar
jabez
Default My turn for problem
Went to pick up sister today. Started my 92 up and let it idle for about a minute. Put car in reverse and car dies and am unable to restart with RPM gauge going wild. Decide to use my other vette to pick up sister. Come back two hours later and try again and it starts like nothing was ever wrong. Try to pull codes and there was none.
What happen and what should I check?
Old Aug 25, 2007 | 08:41 PM
redwing76's Avatar
redwing76
Wild guess the battery.......
Old Aug 26, 2007 | 10:18 AM
mseven's Avatar
mseven
not sure, maybe the charging system....but here is a bump ttt
Old Aug 30, 2007 | 11:59 PM
jabez's Avatar
jabez
Well my problem re-appeared. Did some testing and noticed the engine shuts down when hits 200 degrees. I can let it sit for an hour and it will restart and runs fine but once it hits 200 degrees it shuts down.
Old Aug 31, 2007 | 12:05 AM
RRT vette's Avatar
RRT vette
I would consider checking the CTS in the waterpump since it's temperature related. Done any work in that area lately or any other area?
ICM?
Coil?
Old Aug 31, 2007 | 12:15 AM
jabez's Avatar
jabez
ICM?
Coil?
No. no work at all. In fact I rarely lift up the hood.
Old Sep 8, 2007 | 07:36 PM
jabez's Avatar
jabez
Just talk to the mechanic and he said both my fans are conking out.
They work intermittantly. Going to have him replace both fans, put in
a lower thermostat, and burn another chip for the thermostat.
Old Sep 8, 2007 | 07:59 PM
Da Mail Man's Avatar
Da Mail Man
......you may want to try and hard wire the fans on for a day or so and see if the fans crap ouit on you...why replace them if they are working?
Old Sep 9, 2007 | 08:41 AM
timmy 93's Avatar
timmy 93
Fans are on relays (2) next to the rad. on the driver side.Maybe going bad.
To My turn for problem
