Fuel Rail Cover
Old 08-29-2007, 04:11 PM
jmn02
3rd Gear
jmn02's Avatar
Default Fuel Rail Cover
How do you remove the fuel rail covers?
Thanks,
Jack
Old 08-29-2007, 04:14 PM
vettowner1994
vettowner1994's Avatar
Thanks,
Jack
Your kidding right? Pulling them up works for me.
Old 08-29-2007, 04:44 PM
Road Agent
Road Agent's Avatar
Just give them a tug!
Old 08-29-2007, 05:04 PM
'96 Collector's
'96 Collector's's Avatar
Thanks,
Jack
Everybody has to start somewhere.
Old 08-29-2007, 05:09 PM
shadowman1
shadowman1's Avatar
Thanks,
Jack
Don't do it! It will void your extended warranty!
Old 08-29-2007, 05:36 PM
PUNISHER VETTE
PUNISHER VETTE's Avatar
One of the little tabs broke on mine a while ago so it basically just sits in the hole now. I'm kinda worried it will fall off while driving one of these days...
Old 08-29-2007, 05:37 PM
CINNEMAN
CINNEMAN's Avatar
St Jude Donor '14
if you still have the clip, high temp epoxy it back on.
Old 08-29-2007, 05:39 PM
PUNISHER VETTE
I'll have to check the hole but i'm sure it's long gone by now. It still has one good tab and the loose one holding it so it isn't that bad.
Old 08-29-2007, 06:22 PM
VetteUSA
VetteUSA's Avatar
St. Jude Donor '07
Old 08-29-2007, 10:27 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
First disconect the negative battery lead. (Isn't that step one in every instruction?)
Old 08-30-2007, 08:05 AM
jughead1
jughead1's Avatar
Location: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
Be careful and tug on it lightly and it will just pop off. Do one end at a time. I really can't imagine it happening but if one does happen to break beyond a reasonable repair you can find new ones on eBay all day long.
Old 08-30-2007, 08:18 AM
Mekanic
Mekanic's Avatar
Old 08-30-2007, 09:48 AM
drmrman
drmrman's Avatar
How do you turn the car on?
Im sorry... I had to...
Old 08-30-2007, 01:16 PM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The only one that's even remotely problematic is the driver's side cover due to the throttle cable grommet that's located on it.
Old 08-30-2007, 01:40 PM
jughead1
jughead1's Avatar
St. Jude Donor '11
Yep...and that just simply pops out of the cover.
Old 08-30-2007, 02:59 PM
onedef92
onedef92's Avatar
Then immediately breaks in two from engine heat fatigue. The dealer wants BANK for those lil' ****'s, too!
To Fuel Rail Cover
Quick Reply: Fuel Rail Cover
