91
Sep 2, 2007 | 07:42 PM
5th Gear
i have a 91 c4 hatchback and i use it as a daily driver
i dont thrash it
but i have noticed like after a night of it sittin parked there is a drop or 2 of oil on the ground
is this somthing i need to attend to soon and if not is it bad that i drive it on a daily basis
how much will it cost to fix
ps. 90000 miles
sorry for the spelling i am verry tired i just changed the brakes on my moms car and it is bout a 100 out side o and i suck at spelling anyway
Sep 2, 2007 | 08:04 PM
2015 C2 of Year Finalist
you should first check the valve covers. they are the easiest and cheapest to fix. but only a few drops I would not worry about. when you see a SBC not leaking and fluids you should first check if it has any fluids at all
Sep 2, 2007 | 08:12 PM
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Mines got a few drops too. Always has had a few drops. I'm ignoring the problem... it will go away
One time I had a Saturn, it had a small leak. To fix it was $800. I calculated how much I was leaking (less than a quart every 3000 miles) So I figured at $1/qt, I could go 2400000 miles before I would break even on the repair
Sep 2, 2007 | 08:37 PM
5th Gear
i will check
any thing else i should check
Sep 2, 2007 | 08:38 PM
thats what SBC's do!!!! Dont bother with it until it gets really bad!
Sep 2, 2007 | 09:03 PM
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Hey, it is only marking its territory.
Sep 3, 2007 | 09:37 AM
Quote:
Originally Posted by
Nowhere Man
Start at the top and work down. Also check the area where the heads and intake mate between the engine and firewall. SBCs are known for intake leaks.
Sep 3, 2007 | 10:59 AM
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
A drop or two isn't worth worrying about. With the age and mileage of your car, I wouldn't consider it a problem. Enjoy your car!
Sep 3, 2007 | 02:29 PM
Steel Blue 91
'91 C4 - very well could be the intake gasket. It's about a $550 repair. They go. There's help on the forum to do it yourself and save $'s.
Sep 3, 2007 | 06:28 PM
most likely the intake. I'm having the gasket replaced in Oct. $400. good time to paint valve covers etc.
