1984 1st code..
Not sure if the 84 is the same as 86, but that is a EST code on my car. Check to make sure the EST wire (tan with black stripe) is connected between the brake booster and distrubitor or if the wire insulation is good.
disconnect the neg cable on the battery for 30 sec to clear the codes. That might be your first step to see if the code comes back.
