Codes Reappear
Old Sep 10, 2007 | 09:01 AM
95!Vette!'s Avatar
95!Vette!
Default Codes Reappear
Ok After Clearing the codes in my car about 2 weeks ago the car drove fine and no problems, then it started acting up a little I went to read the codes in my car again and it is showing the same codes I cleared 2 weeks ago H22, and H67.Does anybody have any idea what the problem is?? I thought when you cleared the codes they wouldn't come back
Old Sep 10, 2007 | 11:28 AM
toptechx6's Avatar
toptechx6
The purpose of the codes setting at all is to aid diagnosis of possible problems. If you cleared the codes and they return it is likely there is actually a problem that must be corrected.
Here is a link that describes the codes, but you will need a service manual to troubleshoot and correct the actual problem. Keep in mind that a code that mentions a sensor does NOT indicate the sensor is bad, it simply identifies the circuit that is outside the parameters the PCM recognizes as correct, good luck.
http://chevythunder.com/199295_lt1_trouble_codes.htm
Old Sep 10, 2007 | 12:00 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
The codes let you know theres a problem, clearing without fixing the problems will result in codes returning...
Old Sep 10, 2007 | 01:29 PM
shadowman1's Avatar
shadowman1
22 is throttle position sensor out of range
Old Sep 10, 2007 | 01:42 PM
95!Vette!'s Avatar
95!Vette!
As for the H22 is the Tps voltage low I replaced my Tps about a month ago brand new from napa the code went away, There has to be something wrong when Im driving my car on the interstate or open road my service asr, asr off light comes on and sometimes when I go to put the car in park then reverse there is a hard shift in the gear
Old Sep 10, 2007 | 09:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
DTC 22 sets when TPS voltage falls below .23 volts.
Normally should be arouind .6 volts at idle.
If DTC 22 sets Malfunction Indicator lights, the following will happen.
No transmission torque converter lock, high transmission line pressure, harsh shifts, fixed shift points and no 4th gear in hot mode.
When the TPS is replaced, you're supposed to use a Tech 1 so the ABS/TCS system can learn the new TPS voltage at idle.
1)Ignition off
2)Connect Tech 1 with Mass Storage Cartridge
3)Turn ignition to Run
4)Follow menu to ABS/TCS feature
5)Select F5 TPS Learn
6)Press Up arrow to begin learn procedure
7)Wait for Tech 1 to indicate complete
8)Ignition off
9)Remove Tech 1
I'm sure many people have replaced the TPS without doing the Re-learn procedure but since you're having a problem and replaced the TPS it's possible it could be causing your problem.
You could also disconnect the battery and reseat the 4 connectors on the PCM.
DTC 67 is a problem with the AC system.
For some reason when the AC is supposed to turn on (compressor clutch engage) the PCM is not seeing a pressure change of at least 9psi.
DTC 67 is used to detect problems with the AC compressor clutch circuit and the Refrigerant Pressure Sensor.
Old Sep 10, 2007 | 10:07 PM
95!Vette!'s Avatar
95!Vette!
Ok what is a Tech 1 and Where would I find one at??? Also where do I connect the Tech 1 at on my car ??? What you just said sums it all up in my car the exact problems thats whats been going on....
Old Sep 10, 2007 | 11:43 PM
Hooked on Vettes
The Tech 1, or Tech 1A (a latter model) is a hand held tester used by GM service people to trouble shoot older computer controlled engines.
You can find them used on E-bay for around $175.00 plus you need the Mass Storage Cartridge which contains the Software Programs and the proper cable adapter to hook to the 16 pin diag. connector above the driver side knee.
Or you can go to the dealer and have it done.
Old Sep 11, 2007 | 02:30 PM
95!Vette!'s Avatar
95!Vette!
I cant seem to find this Tech1 on ebay I have looked everywhere and cant seem to find it
To Codes Reappear
