Automatic Shift Points
Old Sep 10, 2007 | 07:58 PM
dbone's Avatar
dbone
Cruising
Default Automatic Shift Points
I HAVE A 94 LT1 AUTOMATIC. K&N AIR FILTER AND BORLA EXHAUST. HOW DOES THE SHIFT POINTS GET ADJUSTED?SEEMS ITS REAL EASY TO HIT THE REV LIMITER PRIOR TO THE CAR SHIFTING.
Old Sep 11, 2007 | 12:00 AM
Hotred94's Avatar
Hotred94
The trans is controlled by the main computer, so you will need to reprogram that to change shifting.
Old Sep 11, 2007 | 07:23 AM
chucks88's Avatar
chucks88
If you feel comfortable digging into your valve body, B&M sells and springs and weight kit that allows you to adjust the shift points.
Old Sep 11, 2007 | 09:00 AM
Casethecorvetteman's Avatar
Casethecorvetteman
No they dont. This is a 94, the PCM has all the say in what gear is selected at what speed.
Here is the table for it:
Dbone, unless the shiftpoints have been changed, the rear end ratio has been changed, or the transmission is slipping on the shifts, it shouldnt hit the rev limiter unless youre holding it in a particular gear. If you get Tunercat and an ALDL cable, i can change the shift points for you.
If the rear end ratio goes up numerically, it will shift gears at a higher RPM because the PCM commands shifts on the basis of TPS% vs MPH (see table above).
Old Sep 11, 2007 | 09:37 AM
LilR3dCorvette's Avatar
LilR3dCorvette
St: Jude Donor '10
I also have a '94 LT1 auto with the same mods as you (I have the 3.07 gears). How many miles do you have on your vette? If you have high miles, and it revs out, then your tranny might be starting to slip. Ask me how I know.
I recently had my tranny rebuilt and had them tighten up the shift points via a tune (reprogramming the computer). Shifts like a champ now
Old Sep 11, 2007 | 09:52 AM
NCBLACKC4's Avatar
NCBLACKC4
I have the same set up with 315 gears, i have the hypertech tuner, so i can change shift points at any time.
Old Sep 11, 2007 | 11:49 AM
ineVETTEable's Avatar
ineVETTEable
This is a good topic.
I hit rev lmtr frequently, and figured the trani may be the culprit.
I too have a 94 with no mods but exhaust and filters.
Only hit limiter when I tromp her down and the trani down shifts into scream away gear. Then I bounce of the limiter.
Old Sep 11, 2007 | 12:40 PM
Casethecorvetteman
It shouldnt allow that if its all on stock settings, it should shift before it gets to the rev limiter.
Old Sep 11, 2007 | 12:48 PM
LilR3dCorvette
St: Jude Donor '10
100%. I still think this is the sign of a slipping transmission or other problem.
When my tranny started failing at 92ishK miles, it would rev out pretty high before it would shift, i.e., it was slow to shift into the next gear. Even if you floor it/drive your car hard (I know I do), a healthy transmission and/or computer will shift before it hits the rev limiter.
Now with a very well rebuilt tranny, bigger stall, and a very tight tune on the tranny (I asked for the most neck-snapping shifts possible), my car shifts quick and hard, it never bounces off the rev limiter.
Old Sep 11, 2007 | 03:10 PM
9vette4's Avatar
9vette4
MMMm....... I have just about the same set up as
you guys are talking about. Thanks for that little bit of info.
Old Sep 11, 2007 | 10:46 PM
chucks88's Avatar
chucks88
Nice....lot less messy that way
Old Sep 12, 2007 | 01:04 AM
Casethecorvetteman
Flare up, if its revving up abruptly at the point of shift, that is slippage in the next gear sellected.
Very much so.
Old Sep 13, 2007 | 10:36 AM
ineVETTEable
slippage into the next gear? doesn't seem as though it's shifting out of the previous gear befor it hit rev. lmtr. Kind of like it's locking out or maybe not developing the proper pressure to move valves or what have you, to force the next gear. could dirty filter and oil be the cause. Dip stick oil looks red-not burnt. but filter?? who knows.
Old Sep 15, 2007 | 11:27 AM
Casethecorvetteman
I spose if the pressure is down it might cause it, i really dont know, but id guess it would still do the same as i decribed if its lacking pressure, cause when it attemps to engage the next gear and the clutch pack starts slipping (be it lack of pressure or just lack of clutch material, slipping is slipping), it may seem as though its still in the same gear until the rev limiter cuts in and power drops off which gives the clutch pack a chance to grab.
My 94 did it and the fluid was still red, didnt smell burned either, but when i had it serviced and we broke the filter open, it was full of clutches.
Not sure how well youll see it, but here is the opened filter, you might be able to see the clutch material in there...
Old Sep 16, 2007 | 12:14 PM
ineVETTEable
Yes, lower RPM's and grabs. makes perfect sence. From what I can tell from the pic. it looked...well, bad. Two quickies for ya,
1.) Did it solve your issues? (Rev~slippage)
B.) Did you dump all oil and replace filter or just pan oil and filter?
Old Sep 16, 2007 | 04:05 PM
Casethecorvetteman
1: Not much at all, the damage was done and the clutch packs had next to nothing left on them.
2: Servicing a transmission means replacing the fluid, the filter and the pan gasket.
I rebuilt it a week later cause it was under warrantee.
To Automatic Shift Points
