wheel squeaks ?
Old Sep 13, 2007 | 09:33 PM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Default wheel squeaks ?
Sounded like squeaking coming from the right rear wheel today as I was driving. I could hear it clearly when it was happening as I drove slowly with the stereo down. It would go on and off sporatically. Most of the time, wouldn't make a sound. Is this just something I may need some brake squeak spray on or is it typically somethin else? It isn't grinding or anything from what I can tell. I had that happen with the rotors before I had a pair replaced. I'm wondering because It has been raining here alot lately. TiA.
Old Sep 13, 2007 | 09:45 PM
aminnich's Avatar
aminnich
Options--Brake pads--not highly likely,
Wheel bearing--not likely
Half Shaft U-joint--Likely
Old Sep 14, 2007 | 01:40 AM
MaSTeRofDZaSTeR
I noticed how much damage they can do if they're ignored....How regularly should these half shaft U joints be greased/checked? Also, if I don't do it myself, how long would it take or how much would it typically run if a shop did it?
Old Sep 14, 2007 | 04:45 PM
aminnich's Avatar
aminnich
Factory joints are sealed (no zerk fittings for greasing). There are threads on here about the best replacement u joints (spicer I think).
Shops charge too much for these, but not a bad dyi deal. I think I saved the instructions here somewhere. But let's not get the cart before the horse. Jack it up and check everything first, it could still be one of the less likely options.
Old Sep 15, 2007 | 10:22 AM
gixxr's Avatar
gixxr
Half shaft U-joints absolutely, mine made the same noise before they finaly went
Old Sep 20, 2007 | 11:09 PM
MaSTeRofDZaSTeR
The u joints for the rear axle(depending on which one) are "half-shaft" I take it? They don't look too expensive. I'm having someone take a look at em tomorrow. If I can't grease the old ones, how long do new ones typically take to put in?
Old Sep 20, 2007 | 11:29 PM
aminnich's Avatar
aminnich
Yes, half shafts connect the center diff to the wheels, two u-joints each side. Doubt grease would help, if they are squeaking they are shot. Step by step intructions sent via PM.
Old Sep 20, 2007 | 11:37 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I just finished this job up. Mine were sounding very similar to what you described. There's a lot of discussion about which u-joints to use, I decided to go with Spicer (they are the OEM for the originals). After gathering all the parts I only had about 3 1/2 hours in the R & R. I don't know if that is a good time or not, but I felt pretty good about the time frame.
I did some cleaning under there while I was at it and replaced some bushings (sway bar) and the tie rod boots.
To wheel squeaks ?
