Clam shell, help or hinderance
Old Sep 15, 2007 | 11:11 AM
ps374's Avatar
ps374
Default Clam shell, help or hinderance
Be doing a lot of work on my C4 and started to wonder if the clam shell was really better they previous and current Corvettes in ease to work on. Yes its easy to reach grease fitting, and battery, but I notice that its brutal on the back since you have no fender to lean on. Looking at the C1 it seems like the easiest to lean on and work. The C2s fender hump seems like a problem and the C3 seems OK but like all Corvettes they are low. Plus the weight of the clamshell seems at times trying when its a one man job opening and closing. What have been others experiences who maybe owned a different generation Corvette.
Old Sep 15, 2007 | 11:46 AM
Wayne88's Avatar
Wayne88
I either feel the lower back. or my age, or both, the next day.
Old Sep 15, 2007 | 11:58 AM
Gonzo's Avatar
Gonzo
Own a c4 an a c5 and have spent time with other hoods as well
The clam shell hood on the C4 is in my opinion is very cool. I like better than most any other design on a mass produced car. It's also frendly to me in that I can rest on the tire or stand on it and not worry about the paint.
Plus the engine bay looks really cool as well with both tire wells open like that, just says race car to me
Old Sep 15, 2007 | 07:16 PM
GIMMESOME's Avatar
GIMMESOME
Sometimes when I'm working on it I can sit on the tire,that helps my old back quite a bit.
Old Sep 15, 2007 | 07:51 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I have used the tires as a seat when working on the headlights. Overall the clamshell opens up the engine area better than any other car.
Old Sep 15, 2007 | 08:01 PM
RWD_tech's Avatar
RWD_tech
the clamshell hood is not intended to make the car easier to work on. thats about the last concern lol. the clamshell eliminates a lot of body lines you would see on a car with a normal hood. its a styling feature
Old Sep 15, 2007 | 08:17 PM
86PACER's Avatar
86PACER
Use the front tire as a seat, if you can fit.
Old Sep 15, 2007 | 08:54 PM
JackDidley's Avatar
JackDidley
I owned/worked on a C3 for 14 years. Over 200k miles. I hated to deal with that big white fender. Fender covers never stay exactly where they need to be. Spilling brake fluid, oil, whatever always a possibility. Not to mention, if you need some one else to do repairs. If it aint their car, they are not as careful about these things. I dont worry about scratching a tire on my C4 when doing service.
Old Sep 15, 2007 | 09:39 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
The clamshell has never been a problem for me. I like it.
Old Sep 15, 2007 | 09:47 PM
Demonic85's Avatar
Demonic85
I like the clamshell in that it makes it easier to work on the under hood components, but it weighs a lot. I dont know if you guys have the shock assist thing but all i've got is that stupid folding hinge.
Old Sep 15, 2007 | 10:11 PM
Sunstroked's Avatar
Sunstroked
I like the access the C4 clamshell provides. I did some work on a C3 before it was tight. As for height of the C4, I lowered mine using VBP's springs, and all I can say is its about as low as you can go. Depending on what Im doing I put the car on jackstands to ease the strain on my back.
Old Sep 15, 2007 | 10:17 PM
tonymax2's Avatar
tonymax2
I've been working on cars for over 40 years and the first thing I questioned when I started looking at buying a C4 was, "Is this better than a fendered car to work on?". I was concerned since, in my 6th decade, my back doesn't take it like it used to much less my knees. After many examinations of C4 engine compartments at car shows, I decided I liked the clamshells access but would build a "belly" rest to lean on for most jobs on the engine. This would fit on the lower wheel well where the hood rests or the tire-might need one for each side. Since I don't have the C4 yet, I haven't designed these but after a summer full of working on cars (now my sons), I know they're gonna get build 'cause the strain isn't getting any better and I still don't cotton to letting someone else work on my cars!
Old Sep 16, 2007 | 01:00 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Old Sep 16, 2007 | 09:57 AM
ecorse66's Avatar
ecorse66
I really like the clamshell for engine access. If it's too hard to lift check out the two small lifts at the front of the hood. Mine were shot and the clamshell was a struggle to lift. New lifts = no problem! The lifts are about $8 each at http://www.rockauto.com. They install in about 10 minutes. I did have to get a helper to support the hood while I put them on my '86. Unbolting the top brackets (2 bolts) made them easier to install. They make the most difference in the last 1/3 of the hood opening. Mine hold the hood up with no weight on the hood prop.
Dave T.
Old Sep 16, 2007 | 09:26 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Old Sep 16, 2007 | 10:50 PM
C4DERF's Avatar
C4DERF
Other than having a vw Dune buggy or baja buggy the clam shell hood makes it so easy to work on the entire engine compartment. As for the raising and lowering of the hood on a C4 it goes up with one hand and I use both hands to lower it so as not to slam it shut. Mine is very well balanced.
Old Sep 16, 2007 | 11:12 PM
300HPisnotenough's Avatar
300HPisnotenough
None of you know the purpose of the clamshell hood, do you?
It's so you can put your beer on the tire while you're working on the car.
To Clam shell, help or hinderance
Old Sep 16, 2007 | 11:13 PM
VtVette's Avatar
VtVette
I found the same thing here. I did a lot of work on a '80 C3 for a customer a few years ago and it was a MAJOR PITA to deal with the front fenders and narrow hood opening. I love the clamshell hood. I find it perfect for service work. The only PITA about the clamshell hood is aligning it if you remove it can be a real challenge. Hopefully most people here won't ever have to do that.
Another plus for the design is they left the front bumper and lower fenders separate from the hood. I work on several Jaguar E Types at work and it has a similar hood but the entire front clip hinges up. It's a M*A*J*O*R PITA to work under the hood for any length of time. The hood doesn't open that far because the front rubber bumpers hit the ground and you have to be very careful to avoid hitting your head on the lower corners of the hood.
It's no fun working under that hood believe me. The Vette is a great design.
Old Sep 17, 2007 | 12:41 AM
Goldcylon's Avatar
Goldcylon
Best answer yet
Old Sep 17, 2007 | 10:09 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Originally Posted by Goldcylon
Best answer yet
