spark plugs
Old Sep 19, 2007 | 05:08 PM
gvrabac's Avatar
gvrabac
Default spark plugs
hey guys,
I bought a 90 vert and was doing my own minor tune up. The first mistake I think I made was using NGK plugs. When I purchased them i noticed that they were shorter than the delco's I took out. What plug should i be using? the car does not seem to be running right. I don't want to have to change these things again.
Old Sep 19, 2007 | 05:12 PM
mothersworry's Avatar
mothersworry
The NGK can be a good plug. Which NGK are you using? I use the TR-55 with great success. A lot of guys use the old faithful AC Delco Triple Platinums.
Old Sep 20, 2007 | 02:30 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Recently installed NGK TR55ix (iridium), gapped at .050 - .051 OEM gap in our 94 LT1 engine and they seem good so far.
However, they did appear the same size/length as OEM AC/Delco's.
Be careful of assumptions -- are you sure the plugs in the car were the correct plugs?
Note: your engine is different than ours (L98).
Which NGK's did you install? What Gap? Did you torque them carefully using a torque-wrench to spec torque (probably 11-15 ft/lb)?
Old Sep 20, 2007 | 03:37 PM
ineVETTEable's Avatar
ineVETTEable
I went with exact factory replacement AC plat. I think they were like $6 each. 'course I think NAPA bent me over, or perhaps they used the "Special" Corvette cash register.
Old Sep 20, 2007 | 03:46 PM
RRT vette's Avatar
RRT vette
The NGK plugs are good plugs. Just make sure you got the right numbers and gap them at .035. The TR-55 are for the LT1 engines. Search on the internet at napa and see if you got the right numbers. Other than the NGK plugs I would get the stock AC Delco's. A spark is a spark. The cheapest spark plug you can find will work just as good as any of the others. The only down side to a cheap plug is how long it last. If you change plugs as regularly as I do (every few years), you shouldn't have a problem.
Old Sep 20, 2007 | 04:25 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
AC Delco best bang for the buck
Old Sep 20, 2007 | 06:25 PM
Steel Blue 91's Avatar
Steel Blue 91
Rapid Fire # 5 for me.
Old Sep 21, 2007 | 11:49 AM
NEVRL8T's Avatar
NEVRL8T
NGK TR-55 here.
Old Sep 22, 2007 | 11:25 PM
gvrabac's Avatar
gvrabac
hey guys, just looked at the plugs that part source sold me. They are NGK V-Grove. I think they are the wrong plug. the lenght is completly different. the threads are only about 1/2 inch in lenght.
Old Sep 23, 2007 | 12:10 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Ngk Tr55
Old Sep 23, 2007 | 12:43 AM
Demonic85's Avatar
Demonic85
Well depends on the year you have. '84-'86 with iron heads use a shorter plug, '87-'91 use a longer plug and I have no idea what the LT1 uses.
I use Bosch Platinum by the way. AC Delco is good, never used NGK before but many people like it. Dont use Autolite plugs though they suck. I had to put them in mine and 3 months later a couple are fouled already.
Old Sep 23, 2007 | 04:09 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Originally Posted by TheAngelOfDeath
NGK TR-55 here.
No problems with them in my LT1.
Old Sep 23, 2007 | 04:40 PM
RWD_tech's Avatar
RWD_tech
Originally Posted by gvrabac
hey guys,
you probably crossed a wire, or didnt fully tighten a plug allowing a compression leak. or they are improperly gapped
To spark plugs
