'86 Light Switch knob
Old Sep 24, 2007 | 05:23 PM
abdo's Avatar
abdo
2016 C1 of Year Finalist
Default '86 Light Switch ****
I have a simple question. Often when I turn on the headlights, the **** comes right off into my hand. There doesn't seem to be anything broken in the plastic core or the switch stem. Any of you have this problem?
Old Sep 24, 2007 | 05:29 PM
The Beep's Avatar
The Beep
I just put a little epoxy on mine and its secure.
Old Sep 24, 2007 | 05:30 PM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
You still have a ****? Then you're way ahead of me!
Old Sep 24, 2007 | 06:06 PM
ecorse66's Avatar
ecorse66
The factory **** has a small flat metal spring release that lets you remove the **** from the rod. There is a small notch in one side of the **** where the release spring is visible. It sounds like this spring is missing from your **** or the plastic around the spring is cracked and not letting the spring 'bite into' the shaft.
To release it you use a small screwdriver to depress the spring toward the face of the **** while pulling out the shaft. On an 86 you have to remove the **** in this manner before you can remove the dash trim plate to access the switch. Therefore I wouldn't epoxy the **** to the shaft.
There is also a push button type release on the switch itself which will release the **** and shaft as one unit, however I'm not sure it's possible to get a human hand up under the dash to accomplish this without the trim panels removed. Kind of a "Catch 22."
If you bought a generic headlight **** at the parts store, the **** may be molded onto the shaft and therefore it is not possible to separate it from the shaft. You will find an original or reproduction **** from a Corvette dealer much easier to install. You just push it on. Only problem is the price! Good luck!
Dave T
Old Sep 24, 2007 | 06:28 PM
The Beep's Avatar
The Beep
Dave T
The epoxy is still a quick easy fix. If somewhere down the road you need to completely remove the trim plate, you can break/cut the **** off. Afterall, it's hosed anyway.
Old Sep 24, 2007 | 06:38 PM
ecorse66's Avatar
ecorse66
You've got a point! Gluing the **** on doesn't cost anything and it is an easy repair.
Dave T.
To '86 Light Switch knob
