brake issue please help
Old Sep 26, 2007 | 02:46 PM
nightsor's Avatar
nightsor
Default brake issue please help
i have a 90 coupe and i changed all the brake pads now on the front i hear a rattle and i noticed there are no bias springs on the pads could this be what is causing the rattle thank you in advance
Old Sep 26, 2007 | 03:54 PM
jrp's Avatar
jrp
That's the first thing to try. There is a reason why most here refer to them as "anti-rattle" clips/springs. Even if they don't fix the problem, they are supposed to be there. If your new pads didn't come with them, scavenge from your old ones.
I did experience a clunky caliper even with the springs, however, and the fix was a new set of rotors. I had a set of slotted/drilled front rotors turned last spring - it solved my vibration once they were reinstalled, but the caliper rattle started for reasons I was never able to figure out.
Old Sep 26, 2007 | 03:59 PM
jrp's Avatar
jrp
Here's a photo to make sure we're talking about the same thing:
Old Sep 26, 2007 | 04:27 PM
nightsor's Avatar
nightsor
i will get new rattle clips and if that does not work i will check the rotors although they were working fine with the old pads thank you for the reply
Old Sep 26, 2007 | 04:29 PM
nightsor's Avatar
nightsor
these are the clips i am talking about thank you
Old Sep 26, 2007 | 04:33 PM
Lars87's Avatar
Lars87
when I seen photo like that, I allways wonder WHY did GM egineers not use the hole swepts area of the rotor!
Old Sep 26, 2007 | 05:16 PM
jrp's Avatar
jrp
Probably because of the diminishing returns w/ respect to torque as it is applied closer to the axle vs. caliper size & weight.
The unswept portion also might be intended to act as a heat sink.
Old Sep 27, 2007 | 09:00 AM
Lars87's Avatar
Lars87
The gain of having a larger pad and friction area, should make the pad more effectiv and the bigger pad had has better heat sink properties too.
I have noticed the same on c6 c5 and and z06 vettes, and always wonderd why they dident want to use as big a pad as possible. When you look at brake systems on Ferraris etc the pad is only a few mm from the hub.
Old Sep 27, 2007 | 10:54 AM
jrp's Avatar
jrp
But the pads aren't actively cooled as the rotors are, via the vented discs.
Keep in mind that I wasn't pretending to know, but was guessing at what the reasons might be. It would be surprising to find out that GM engineers are unfamiliar with other brake systems, so there must have been some tradeoffs to consider.
Old Sep 27, 2007 | 03:42 PM
nightsor's Avatar
nightsor
thanks for the help to quetions i did not ask
To brake issue please help
