Throttle got stuck!!!!!
Sep 26, 2007 | 06:30 PM
Cruise-In X Veteran
I had made a left hand turn and then my throttle stayed about 20% in and wouldn't stop. Any ideas?
Sep 26, 2007 | 06:42 PM
St. Jude '03-'04-'05-'06-'07
Year/engine:
L98 - stuck cable, bent TB Bracket, stuck TB plates
other yrs????
Sep 26, 2007 | 06:43 PM
Cruise-In X Veteran
Sep 26, 2007 | 08:19 PM
Quote:
Originally Posted by
vinnies87
Year/engine:
other yrs????
Actually sticking TB plates is most likely. Can of TB cleaner and some seafoam in the tank might clear that up.
Sep 27, 2007 | 10:12 AM
Is it possible that you hit the cruise control "accelerate" button while turning on the blinker?
Sep 27, 2007 | 12:56 PM
St. Jude Donor '08-'09
I was out "racing on a track safely" one night and at the end of one of the runs, my throttle was stock at WOT!!! WTF?!?!
I quicky feathered the clutch back to the parking area, killed the engine and popped the hood.
Throttle return spring had broke!!
Luckily a pair of needle nose pliers bent the remaining spring piece enough to make a new one and it worked fine to get home.
Sep 27, 2007 | 01:00 PM
GIJoe
This is why most racing organizations require 2 return springs - and check it during inspection!
Carl Johansson
Sep 27, 2007 | 01:48 PM
mrmoore
yep
Your lucky it only got stuck at 20% throttle and not WOT. In any cause I agree with everyone else, clean the throttle body and check the throttle cable to see if its snagging on anything.
Sep 27, 2007 | 09:48 PM
Cruise-In X Veteran
I will definetly be checking all of the above if there is a particular throttle body cleaner that is better than the rest chime in and any other ideas too. I am completly puzzled about it.
