Hello and help please
Old Sep 27, 2007 | 07:58 AM
rpieper's Avatar
rpieper
4th Gear
Default Hello and help please
I am new to the forum and want to say hello to all. Recently purchased a 1990 vert. black on red. Love it. I am trying to remove the passenger side door panel but can't get to the last screw behind the door lock. I hate to pry and pound on it without knowing exactly how it's put together. Any help would be appreciated.
Old Sep 27, 2007 | 08:12 AM
jimmers's Avatar
jimmers
Pry at it with a screw driver, and it will pop off.
Old Sep 27, 2007 | 08:16 AM
pianoguy's Avatar
pianoguy
Just pry the lock **** out, and you'll be able to access that last screw. It's easy to pop back on when you're done.
Old Sep 27, 2007 | 08:18 AM
NEVRL8T's Avatar
NEVRL8T
There is also a screw behind the window switch.
Old Sep 27, 2007 | 09:47 AM
rpieper's Avatar
rpieper
4th Gear
Thanks for the tips. I'll give it a try.
Old Sep 27, 2007 | 09:50 AM
mrmoore's Avatar
mrmoore
I used to work on auto locks as a locksmith.
TIP: Plastic gets brittle when it gets cold. Be sure (if you can) to work on interior items when it's warm. And if you have to work on it in the winter, a hairdryer in the car does a good job keeping things warm and more flexible.
Old Sep 27, 2007 | 12:23 PM
kalister1's Avatar
kalister1
The black plastic cover on the door lock slide comes off and there is a screw behind the light too.
Old Sep 27, 2007 | 02:07 PM
thebeerman's Avatar
thebeerman
don't forget "there is a screw behind the light too. " just mentioned.
Old Sep 27, 2007 | 06:09 PM
beach5's Avatar
beach5
Welcome!
Rule #1 - Post pics of your newly acquired Vette
Old Sep 27, 2007 | 06:37 PM
pianoguy's Avatar
pianoguy
Also, the screw behind the light is the shortest one - make sure you put it back in the same place.
To Hello and help please
