Emergency Fixes
Old Sep 28, 2007 | 08:19 AM
mdlfcrss's Avatar
mdlfcrss
Default Emergency Fixes
After reading Jimbomill's thread about the "leaking radiator and the egg" I realized there are quite a few emergency fixes out there. Here's a few of the fixes already mentioned...
1. Egg, nutmeg or black pepper to seal a radiator leak.
2. Coke on battery terminals to clean corrosion
3. Aspirin in battery to bring it back to life
4. Bar of soap on a gas tank to stop a small leak
5. Cuisinartvette said something about a banana and a piehole
Anybody else have any good ones we can all benefit from?
Old Sep 28, 2007 | 08:40 AM
NEVRL8T's Avatar
NEVRL8T
Duct Tape - end of thread.
Old Sep 28, 2007 | 08:47 AM
pianoguy's Avatar
pianoguy
Keep some Plastex on hand to fix broken plastic parts.
Old Sep 28, 2007 | 09:04 AM
mdlfcrss's Avatar
mdlfcrss
Who doesn't have a roll of duct tape in their car?
Old Sep 28, 2007 | 09:43 AM
kalister1's Avatar
kalister1
I know some people that think Duct Tape is a Permanent repair.
Old Sep 28, 2007 | 09:49 AM
Demonic85's Avatar
Demonic85
I used duct tape a lot on some other cars, havent needed it for the vette. JB Weld and a screw makes for a good repair if someone punctures your gas tank with a screw driver.
Old Sep 28, 2007 | 11:40 AM
The Beep's Avatar
The Beep
Holy Krap! Did you tork someone off or was someone being a dink?
Old Sep 28, 2007 | 04:34 PM
mdlfcrss's Avatar
mdlfcrss
Thats exactly what I was thinking!!!
Old Sep 28, 2007 | 08:35 PM
Kinkajou's Avatar
Kinkajou
Crazy glue ( cianoacrilate) + backing soda or alka seltzer helped to control a leak at the power steering pressure hose because of a broken Oring.
It works also to repair plastic parts.
Old Sep 28, 2007 | 08:59 PM
Jim Nichols's Avatar
Jim Nichols
Do you mean duct tape isn't a permanent repair. It's even better in colors other than gray.
Old Sep 28, 2007 | 10:19 PM
kalister1's Avatar
kalister1
I have some green stuff, they call it 200MPH tape. That stuff is the SH*T
Old Sep 30, 2007 | 12:42 AM
C4boy's Avatar
C4boy
That would be my father. Who had the air box duct taped to the radiator shroud when I bought the car!
Old Sep 30, 2007 | 08:00 PM
martymcfly's Avatar
martymcfly
I am surprised that nobody has mentioned the coat hanger for the radio antenea or for muffler hanger. How about the matchbook to shim up the old 8-track tape. I must be a redneck, because I could go on and on.
Old Sep 30, 2007 | 10:12 PM
champs65's Avatar
champs65
Keep a radial tire repair kit in the car. (plugs and scratching tool) Takes up no room, and gets you back on 4 real wheels when you get to an air compressor.
Old Sep 30, 2007 | 10:15 PM
VtVette's Avatar
VtVette
Keep a few tie wraps (or zip ties) in the car as well. they can be used for all sorts of things and are strong as hell.
Also, the soap trick works amazingly well. I've done this personally when off roading and punctured a tank in a truck. Sealed it right up all the way home.
Old Oct 1, 2007 | 11:02 AM
mdlfcrss's Avatar
mdlfcrss
Ahhh, the old 8-track hanging off the bottom of the dash, held up with 4 different sized sheetmetal screws, matchbook wedged under the tape, speaker wires stuffed up behind the dash wrapped up with electical tape. Those were the days
Old Oct 1, 2007 | 11:32 AM
Sunstroked's Avatar
Sunstroked
I keep a AAA gold card in my wallet. The vette hasn't needed it but every other car I've owned has put it to good use.
Old Oct 1, 2007 | 01:51 PM
Aardwolf's Avatar
Aardwolf
Exhaust rust in two? Drink a beer, wrap can around exhaust pipes and clamp it.
To Emergency Fixes
