Potential cold weather solution
Old Sep 28, 2007 | 05:52 PM
Fast Doc's Avatar
Fast Doc
Default Potential cold weather solution
Summers shot to $hit in most areas of the country. My desert environment is getting its first true rainy day in 5 months today. The thermometer is dropping, but I want to keep the top down .
I also ride motorcycles (mostly, actually) and I have an electric vest that plugs into the battery or electrical system.
It keeps me very warm on the bike, even if the temp is in the high 30's. I won't ride if its any colder than that for fear of ice .
I was thinking about rigging it up to plug into the CE's cigarette lighter and wearing it in the car.
Has anyone done this? Any thoughts? FWIW, it draws 30 watts.
Bill
Old Sep 28, 2007 | 06:26 PM
The Beep's Avatar
The Beep
Whatever floats your boat. The way I see it is cold = top up, hot = top down. Convertable or a car that converts.
Old Sep 28, 2007 | 07:00 PM
Fast Doc's Avatar
Fast Doc
Thats true, but I just can't stand it. I need the wind on the old bald spot. I get claustrophobic with the top up
Old Sep 28, 2007 | 08:46 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
As long as the current draw on the cig lighter doesn't overload the circuit, why not plug in the vest? If you do blow the fuse don't just put in a bigger fuse, the wires can cause a serious fire. If it works keep the top down, vest on, heater on high, and be prepared to replace every electrical part that you push to the limit. Top up, windows down, and drive fast!!
Old Sep 28, 2007 | 08:53 PM
kalister1's Avatar
kalister1
Power = volts * current
30 = 12 * X
30 /12 = X
You are pulling less then 3 amps, unless it pulls 30 AMPS?
It should work
Old Sep 28, 2007 | 08:58 PM
Fast Doc's Avatar
Fast Doc
Its 30 watts only. I've used such vests on bikes as small as a 250 enduro with no problem.
I'm just not a 'top up' kinda guy.
Old Sep 29, 2007 | 06:55 AM
Da Mail Man's Avatar
Da Mail Man
.....you'll have no problems.....
To Potential cold weather solution
