ABS Controller
Old Sep 29, 2007 | 05:30 PM
rodcreak's Avatar
rodcreak
1st Gear
Default ABS Controller
How do I remove the ABS control module wiring harness connector on a 1987 Corvette?
Old Sep 30, 2007 | 12:35 AM
C4boy's Avatar
C4boy
It just pops right out. There is a plastic tab on the side where all wires enter the harness. Just push the tab out (or in, I forget) a bit and lift.
Old Sep 30, 2007 | 05:26 PM
86PACER's Avatar
86PACER
On one side there is a metal latch. On the other end is a small flat tip screw that you must remove first. Once that small screw is out, unlatch the connector and pull up.
To ABS Controller
