Normal for a 4+3?
Old Sep 30, 2007 | 11:09 PM
The Beep's Avatar
The Beep
Originally Posted by Bensons86
I also hear a lot of folks just flipping the switch as an automatic 5th gear. Ultimately is this the best way to use it?
I should also mention that my switch is separate from the gear shifter. The previous owner separated it.
From neutral OD off; clutch, 1st, clutch, 2nd, clutch, 3rd, clutch, 4th, clutch, OD.
Plus change AT fluid/filter every 12k.
Also note, the OD will not work until engine temps reach about 140f or so.
Old Oct 1, 2007 | 09:35 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I notice on my 85 4 plus 3 when I am slowing down in or out of overdrive there seems to be a slight hesitation as the car slows down.
I just put a stock GM clutch in the car when the tranny was rebuilt and it does not feel too heavy. Real smooth on engagement.
Old Oct 1, 2007 | 10:11 AM
AUTO_X_AL's Avatar
AUTO_X_AL
Originally Posted by OTS_UFN
I also only use the OD at highway speeds. The corvette catalogs have shifter kits from B&M and Hurst but I understand they are labor intensive to install but do cut the shift motion about half. Clutchs, I dunno never had to replace one yet. Still it would be a good idea to check the codes to see if you have some sort of computer problem. The 4+3 is a computer controlled transmission.
Where is Central Coaster when you need him? LOL
You can buy a kit to reduce the throw on the shifter. I have done a few intensive searches to find another shifter but you cannot find something of which does not exist. We have the shorter linkages and I'm of the opinion that it shifts and feels better than a stock ZF6. I have yet to drive a ZF with an aftermarket shifter so I don't have anything to compare that too but I really prefer the shorter 4+3 versus the ZF6. I think the worst part of installing the kit is the alignment and I didn't think it was all that horrible. As far as the OD we just have a simple toggle on/off switch. No more BS with the tranny trying to think for itself. I'm quite capable of doing that for the car.
As far as the clutch goes, ours damn near drives itself with all the torque of the motor. There are a few clutches available for the 4+3. I think Centerforce,Hays,and Sachs(OE replacement) are still available.
