Torque Vs. Horsepower
Old Oct 3, 2007 | 10:34 PM
  #41
Aurora40's Avatar
Aurora40
Originally Posted by rocco16
Torque is how much work an engine can do.
Horsepower is how fast the engine can do that work(produce the torque).
Torque is not how much work an engine can do. Power is how much work something can do in a given time period. Torque is simply a measure of rotational force, or force x a moment arm.
You can have 1000ft/lbs of torque on a shaft that is not turning, which computes to zero horsepower because NO work is being done.
So, horsepower is the real measure of power when it comes to vehicles.
I'm not sure exactly what you are saying here? But for example, I could take two electric motors, both of which produce say 100Kw of power. I could connect them to a common shaft, and run them in opposite directions. Neither one would do work, and of course the shaft would undergo serious strain, but I don't believe it means the motors make 0Kw of power. They simply aren't doing any work. But they have the ability to do work.
Old Oct 3, 2007 | 10:35 PM
  #42
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by Zix
Not to play Devils Advocate here, but then why do the F1 cars have top speeds of well over 200 MPH (256 being an unofficial speed record) when they have very little torque (but over 900HP) being produced from their 3.0 liter engines?
Areodynamics certainly come into play, but F1 cars are most certainly NOT designed for top-speed runs, the open-wheel design and extreme down-force aren't friendly to high-speeds...
Very simple (but I'm going to give you a long winded answer). We both agree that high speeds mean high aerodynamic drag. To attain or maintain a high speed requires a lot of force to overcome the mass inertia or aerodynamic drag. We know that the drag force is against the bodywork. The propelling force that overcomes that drag has only one place to present itself. The tire contact patch. The tire (patch)transmits the force to propel the car. The force comes from the (torque) rotation of the axles, translated through a torque arm (the tire radius.) Assuming roughly a one foot tire radius, the torque applied to the axle is numerically identical to the force magnitude at the tire patch. Take this large torque value, divide it by the ring and pinion ratio, and the transmission gear ratio, and you will see that a small torque initiating from the engine will get multiplied by the overall gear ratio, resulting in a large torque value through the axle, which will then be translated into a large driving force at the tire patch. Small torque in, large torque out. Conversely, however, that requires large (engine) RPM in, small (tire) RPM out. Simple gearing/RPM tradeoff.
Old Oct 3, 2007 | 10:54 PM
  #43
murraybob's Avatar
murraybob
Torque is what you feel when you launch the car. Horsepower is the ability of the car to sustain the pull throughout the rpm range.
Old Oct 4, 2007 | 12:20 AM
  #44
Zix's Avatar
Zix
Yep, you certainly did take the long answer approach! I agree with you, it's all in the gearing. I just really enjoy these threads on "torque vs. horsepower", when in reality is not one versus the other, it's about having just the right amount of each for the application at hand.
Old Oct 4, 2007 | 10:56 AM
  #45
mdlfcrss's Avatar
mdlfcrss
Originally Posted by Ruff Rider
Hmmm now I'm interested, O look there's another chair.... .. ..
Would you guys mind sliding down one?
Old Oct 4, 2007 | 11:13 AM
  #46
rube1975's Avatar
rube1975
you want high HP
with higher torque
Old Oct 4, 2007 | 12:09 PM
  #47
Bensons86's Avatar
Bensons86
Thanks for the overwhelming response. The reason I thought to post this thread in the first place was because some people were talking about the TPI set up being torquie and fun to drive in the city. With that in mind, I thought that I must have been confused because mine doesn't seem too impressive off the line in terms of acceleration.
Old Oct 4, 2007 | 12:18 PM
  #48
65Z01's Avatar
65Z01
Cruise-In II Veteran
Why would anyone ever want anything other than a C4?
Much like the small engines in the F1s due to gov taxes, here it's insurance company "taxes" for young guys.
So, due to the economics of it, they buy a small engine import that responds well to "juicing".
Old Oct 4, 2007 | 01:49 PM
  #49
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
(I said)Torque is how much work an engine can do.
(you said)Incorrect. Work is force times distance. Torque is a force at a distance. A difference.
(I say)What I said was correct. I said "can do (is capable of doing)", not "is doing".
(I said)Torque does not accelerate you, horsepower does....you can have massive torque to the rear wheels and not be moving.
(you said) Wrong. Horsepower does not exist prior to rotation. Torque causes the rotation, allowing you to calculate the horsepower.
(I say)It was correct. Torque does not necessarily cause rotation/movement, since you can have torque applied to a stationary object. Your "hp does not exist prior to rotation" statement illustrates this and is, interestingly enough, exactly what I stated.
Your turn....
Larry
code5coupe
________
not easily impressed....
Old Oct 4, 2007 | 03:09 PM
  #50
SCCA VETTE's Avatar
SCCA VETTE
Originally Posted by rube1975
you want high HP
with higher torque
Sounds like a diesel truck!
Old Oct 4, 2007 | 05:12 PM
  #51
Aurora40's Avatar
Aurora40
You are wrong. The unit that represents how much work something is capable of doing is called "Power".
If what you say is right, that torque = amount of work something can do, then I can do as much work as your LT1 (or whatever engine is in your car). Give me a 4' breaker bar and I can easily make 400+ lb-ft of torque. So if you are right, this indicates how much work I can do. I should be able to accelerate a Corvette with my breaker bar like nobody's business.
However, what you said is not right. Torque has no inherent relationship with work. And I would't be able to accelerate a car for ****.
Old Oct 4, 2007 | 06:09 PM
  #52
redrose's Avatar
redrose
most race car shops have a ''mover''...not much more than a 4ft breaker bar with an end plate to engage the wheel hub studs...standard prank is to fit the ''mover'' on and ask some 110 lb PYT to ''hold this up for a sec'' and watch panic set in as the car starts to roll...even if you're under 110 lb, ugly, and not a horse, i'd guess that (unseen) YOU could prolly generate enough torque to get enough speed to hit the shop wall and do 'some' damage.
gonna find a corner chair myself now, interesting how the vette crew is at least thinking about T and not just swallowing HP
Old Oct 4, 2007 | 06:57 PM
  #53
redwing76's Avatar
redwing76
Dude, what is "horsepower" I've never owned a "horse" but I have owned 425 "horsepower".
"Horses" are stupid animals, 425 "horses" couldn't find thier way out of the barn if it was on fire. But 425 "horses" with 450 lbs of torque could pull that same barn down.
Make mine torque,,,to go.
Old Oct 4, 2007 | 07:49 PM
  #54
dclafleur's Avatar
dclafleur
Fun with math and physics!
Newton second law Force = mass x acceleration
Toss in a little algebra,
acceleration = Force / mass
torque is a turning force when measured at the wheels it is the force at which you turn said wheels.
so… your acceleration, is directly dependent on your force, and in fact assuming your wheels are sticking, your acceleration curve will be identical to your torque curve.
I remembered something from college, and they said all that alcohol kills brain cells.
Old Oct 4, 2007 | 07:56 PM
  #55
Aurora40's Avatar
Aurora40
Yes, but if torque = how much work I can do, I should be able to accelerate the car down the 1/4 mile in the 13's with that breaker bar, not just roll it into a wall.
Old Oct 4, 2007 | 08:00 PM
  #56
Aurora40's Avatar
Aurora40
Yes, it is all math and physics, but not that kind.
You just said your acceleration is identical to your torque curve. So on a car with say 350 lb-ft @ 3200 rpm (216 hp) and say 300hp @ 6000 rpm (a measly 262 lb-ft), that from the time you pass 3200 rpm, acceleration drops off. It has to if what you said is true, because torque already peaked and is now declining.
That is incredibly easy to prove false just by going out and driving your car. See if that really happens, or if in fact it pulls a lot harder at the horsepower peak instead?
Old Oct 4, 2007 | 08:10 PM
  #57
dclafleur's Avatar
dclafleur
Swing and a miss, your rate of acceleration will be lower at that point, you'll be going fast still but your acceleration will be lower.
The reality is your engine cannot rev indefinitely and continue to produce torque indefinitely, however to continue accelerating you want to produce as much torque as you can for as long as possible.
If your torque drops below the point you would be in the next gear, you need to shift, why? to maximize your torque!
Just thought I'd add this to your example, if your car is pulling hardest at your horsepower peak, why is it that we get wheel spin when you hit your torque peak...
To Torque Vs. Horsepower
Old Oct 4, 2007 | 08:23 PM
  #58
Aurora40's Avatar
Aurora40
Ok, if that's the argument you want to stick with... I doubt most people's reality will match it.
So with an L98 for example., your fastest acceleration will come with like 3,500 rpm shifts, just after the torque peaks and acceleration drops (or drops according to you)?
Regardless of whether torque or horsepower causes wheelspin, don't you think it's a hell of a lot easier for the wheels to spin at say 5mph than at say 50mph?
Old Oct 4, 2007 | 08:27 PM
  #59
dclafleur's Avatar
dclafleur
Yes, that is 100% correct, you're getting it.
Yes, it is, unless at 50 mph you just down shifted and hit your torque peak again. Of course there is more that goes into it, but functionally that is true. Gearing does come into play with this.
I'm going to give you the benefit of the doubt and assume you're confusing acceleration with speed.
Old Oct 4, 2007 | 08:34 PM
  #60
Aurora40's Avatar
Aurora40
LOL! I'm pretty sure I already had it. But regardless, what kind of 1/4 mile times does your L98 run with 3,500 rpm shifts?
Well, I was of course thinking of someone accelerating, so there would be no downshifting involved. So when you are in 1st gear and run your car up to the horsepower peak (because you aren't in a hurry, of course), then shift into 2nd. Lets assume a smooth shift so there is no shock to break the wheels loose. Then you are saying at that point as you pass through the torque peak again, you can peel the wheels which were not peeling in 1st at the power peak? Color me impressed.
