New overdrive ?
Old Oct 8, 2007 | 12:22 PM
hmcquade's Avatar
hmcquade
Default New overdrive ?
Should the OD Dash light come on when the engine gets hot enough or should it come on as soon as you push the on button.
Thanks,
Hugh
Old Oct 8, 2007 | 02:33 PM
All2kool's Avatar
All2kool
Engine must warm up for a few minutes before the OD will engage.
Old Oct 8, 2007 | 03:16 PM
The Beep's Avatar
The Beep
Yea, I think he's asking if the od lite turns on when the switch is turned on before the engine warms up. I don't think it does but I'm not sure.
Old Oct 8, 2007 | 08:09 PM
hmcquade's Avatar
hmcquade
Thanks for the answers the Vet is going in the shop hpoefully this week. I am getting the drivers side window regualator upgraded and the Mechanic is going to check out the OD.
Thanks,
Hugh
Old Oct 8, 2007 | 08:20 PM
vettejeff's Avatar
vettejeff
My 86 will jump into o.d. as soon as it warms up. I just push the button to turn it off until Im in 4th on the freeway.
Old Oct 8, 2007 | 08:24 PM
Hwy St*r's Avatar
Hwy St*r
according to this website, which i found about a year ago a '84 has to hit 176 degrees before OD kicks in http://www.5speeds.com/43table.htm it says my '87 has to hit 122 for the OD to engage and that's exactly what it does...
Old Oct 8, 2007 | 08:25 PM
fastrtnu's Avatar
fastrtnu
I know the temperatures were different through the years but my 87 will not go into OD until the coolant hits 50 CELCIUS (I'm Canadian).
Old Oct 8, 2007 | 11:22 PM
hmcquade's Avatar
hmcquade
Thanks. The problem with mine is sometines it goes in and sometines it dosen't
Hugh
Old Oct 9, 2007 | 01:08 AM
matrix040's Avatar
matrix040
if I remember right, it's 114 degrees on my 85
Old Oct 9, 2007 | 01:23 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Minimum coolant temp for overdrive to come on:
84... 176F
85... 140F
86+...122F
The overdrive dash light is wired to the same circuit as the overdrive. It only goes on when the computer is trying to turn on the overdrive.
Gear, speed, coolant temp, and overdrive enable switch are just inputs. The computer decides based on all those inputs. The temp you see on the dash vs. the temp the computer sees are from different sensors, so ~5 degrees of error is normal.
If you're Canadian, turn the English/metric switch to english mode to see what those temps translate to. If you only speak French, then you're on your own.
Old Oct 9, 2007 | 01:25 AM
CentralCoaster
One reason to never ever run a 160 stat in a '84 4+3.
Even the 180F thermostat is too close for comfort. And the high flow stats tend to open a little earlier than advertised.
Old Oct 10, 2007 | 10:15 AM
hmcquade's Avatar
hmcquade
Please explain I do not understand.
Thanks,
Hugh
Old Oct 10, 2007 | 10:54 AM
c4cruiser's Avatar
c4cruiser
84... 176F
85... 140F
86+...122F
Throttle position is also an input. The table in the posted link shows what throttle position in 1st gear you need to hit in order for the OD to not engage until you shift into 4th gear. This does depend on the year so it' snot the same for all 4+3 OD's.
The fact that your OD unit works sometimes may be due to a loose wire at the connector to the OD relay or possibly the wire going into the OD case. These are common areas for OD problems especially when the OD unit does work even if it's sporadic
Old Oct 10, 2007 | 01:44 PM
All2kool's Avatar
All2kool
As does my '86E - OD comes on right at 121 or 122, it could have gone to 122 by the time it took me to look at the temp.
Old Oct 10, 2007 | 02:12 PM
hmcquade's Avatar
hmcquade
Thanks for all the help. I hope to get the Vet in the shop by Friday.
Hugh
To New overdrive ?
