C4 badge removal
Old Oct 9, 2007 | 09:20 PM
92PGC's Avatar
92PGC
Default C4 badge removal
I want to remove the C4 badges from the nose and gas cap cover, so I have a completely flat surface when I use my PC. I thought the badge on the gas cover would be simple. loosen nuts and just tap off. not that simple. Don't want to tap too hard and screw something up. Has anyone removed this.
How do you get to the nut that hold the C4 badge on the nose ? then same question as above.
Thanks in advance.
Al
Old Oct 9, 2007 | 09:24 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
there are 2 speed nuts on each. size #10. take them off. then you need take a thin peice of metal like a feeler gauge and carefully slide it between the badge, and the car. there is a 2 sided tape on the back side of the badge.
Old Oct 9, 2007 | 09:25 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
They are held on with speednuts and double sided tape. There will be holes when you remove them of course. They make molding removal tools that are plastic/rubber as to not scratch the **** out of the paint.
Old Oct 9, 2007 | 09:51 PM
Goldcylon's Avatar
Goldcylon
Also when it comes to the old adhesive try a little dental floss and/or small gauge nylon weed wacker line. Allows you to work both sides of the emblem in a sawing motion after you have removed the speed nuts that is. The dental flow cuts a little better but breaks easier. I used the very small gauge nylon weed wacker line as it wont cut the paint. The remants can be removed with a slow thumbnail and a little wax.
Old Oct 10, 2007 | 01:40 PM
All2kool's Avatar
All2kool
Huh? What on Earth do you mean by 'using my PC' and why would the emblems be a hindrance?
Old Oct 10, 2007 | 01:44 PM
mseven's Avatar
mseven
I would first use some solvent to get the glue loose, then heat.
Old Oct 10, 2007 | 02:06 PM
Goldcylon's Avatar
Goldcylon
Im guessing the "PC" means his trusty "Porter Cable" orbital buffer.
Old Oct 10, 2007 | 02:11 PM
pianoguy's Avatar
pianoguy
When I removed my gas door emblem, I used a hair dryer to soften up the adhesive a bit.
Old Oct 10, 2007 | 03:29 PM
Bob89c4's Avatar
Bob89c4
On the Gas door, lots of 3m adhesive remover, then a hair dryer after it all drys.... Mine was on really good.Took about two days. It finally came off. The more time you take, the less paint u lose. On the nose, two speed nuts, put some dum-dum (Black sticky putty)in the socket so you don't lose them. The nose emblem pops right off.
Have fun!
To C4 badge removal
