vibrating/shaking
Old Oct 10, 2007 | 12:37 AM
corvette8189's Avatar
corvette8189
Default vibrating/shaking
96 vert a4
the steering wheel shakes and vibrates alittle bit when over 70 and it does it really bad when over 100. do i have a problem or do they all do this. i just had an alignment and balanced the wheels. what could be up?
Old Oct 10, 2007 | 01:23 AM
Klondike's Avatar
Klondike
Have the tires rechecked for balance AND ROUNDNESS. You can balance an egg...you just can't roll one. Also you could have a rookie at the tire shop that put the weights on the wrong place and didn't re-spin them to check the balance one last time. Alignment might cause some of that, but you didn't say if it had any directional or handling problems,so I'd say probably a tire.
Old Oct 10, 2007 | 07:43 AM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
First thing I'd do is recheck the tires like Klondike says. If that doesn't work check back in. It could get a tad bit more complicated then.
Old Oct 10, 2007 | 08:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed get the wheels rebalanced at a different shop; sinde front & rear are different sizes you can't rotate wheels & tires front to rear.
If still a problem, have the ball joints checked.
Old Oct 10, 2007 | 08:46 PM
garkahn90's Avatar
garkahn90
I had a simmilar problem with my 90 vert. had new tires. had them reballanced about 3 times. Then I read about road force balancing. Had it done. cost about $130 but smoothed it right out. Pretty cool system. I will tell you if have a wheel problem or a tire problem. Call around and make sure you find someone that knows what they are doing. I got mine done at a shop that specilized in corvettes.
good luck
To vibrating/shaking
