C4 with side pipes
If I remember right, they make a U-Turn near the rear axle and run along the rocker back towards the front and then through the pipe out the side near the rear wheel.
http://forums.corvetteforum.com/show....php?t=1832939
Right MOJO...I looked at the Power Effects side pipes for a long time for my 2nd ZR1. In the end I decided against them because I remembered I didn't like the noise in my ears from the custom made sidepipes on my old '70 LT-1.
Instead I got the Power effects regular twin pipes setup...fit, ease of installing, and quality were excellent Sound control was great... Loud enuff to make a statement in the "open" setting but I adjusted sound with the dial to "quiet" when the right seat governor rode with me.
Sure wish they were still in business. I'd have them on BEAST2 instead of the BBs.
I could visit the shop and take some pics if you could PM me with the info.
Waaaaaaay back in the mid 90s I saw them on a black C4 vert at a local Corvette club show. That vert won its class due in part to how good those pipes looked.
Pic of them on a copper 87:
IMO, it's relative.
As for the size, they are equivalent to a 2.75" cat-back. That's equivalent to the LT size...and much bigger than an L98 tail section. Unless Lawrence-Keech (PowerEffects.com) flat out lied about dyno results, swapping an OEM cat-back for sidepipes will produce gains. (Consider how restrictive OEM mufflers are.)
Based on what I could find for flow/sizing/etc...I estimate these sidepipes as being reasonable to use on any car up to 300rwhp. Above that, you'll start losing some measurable loss due to the exhaust system. If I converted my 383 from a TPI intake to an HSR, I'd probably give serious consideration to swapping exhaust systems. Otherwise, mine satisfies me even on a higher-powered TPI motor.
If I didn't have to "cut" 3 new gaskets to r/r that first coupler piece, I'd probably spend the time/money to do a before/after on the dyno to see what it's really costing. When I pulled my center converter, I was ready to leave that coupler out and see what (if any gain) I could feel. But, they fooled me and "only" cut out the converter and welded in the new one (w/o needing to disconnect anything.) Duh...
Joe's been singing that tune about putting them back into production since 2003....10yrs ago. I would be interesting if they finally are. I considered the retooling costs would be too high for the number of units they could sell to $5k-value C4 owners.
Having a source for new covers...if it ever became necessary...would be nice though.
Last edited by Corvette11972; Jun 28, 2013 at 05:35 PM. Reason: Forgot to add something.
Ground clearance was taken into consideration. I've had WAY more problem with front spoiler hitting in the past several years than the sidepipes. I've never broken a cover.
Using rectangular and shallow tubing -- with the cross-section of nearly 3" pipe is only restrictive in terms of bends. And...as I mentioned, this system is more free-flowing than factory setups.
As I've seen everything from LT1's running headers, no cats, and factory muffers to L98's running noisy-azz flowmasters behind headers, these are a much better option. They're reliable, eye-catching, sound perfect, and don't stop up your exhaust when mounted behind legally-configured converters.
Anyone racing 1/4m track dumps converters and runs true duals. For that scenario, it's not what you want. These are for looks...and function. BTW...they are "real" sidepipes too in they carry actual exhaust out the side.
If you want to do an engine simulation to find out how much power these would steal from a build, model a 500cfm exhaust versus one in the 800-1000cfm range. The later is what you want for racing. You'll see the former isn't going hurt much for a street setup. So, asking about what they'll "support" is a relative question. My side-pipe-equipped 383 is still head/shoulders above any stock L98 or LT1 in this forum. So, I'm happy with what the system provides in looks, sound, and performance.
If you wanted to try and engineer electronic dumps near the inlet "splitter" ... or somehow out the headers, you could have the best of both worlds. Another good thing about this design is you won't burn your calves...like it was possible on C3s.
Thats pretty expensive just for the side pipe look.
I think the early C3's were the only Corvettes that looked good with factory side pipes.
