fuel pump
Old Oct 15, 2007 | 03:37 PM
93-383's Avatar
93-383
Default fuel pump
Does anyone know wether the fuel pump is positive displacment or centrifugal.
Old Oct 15, 2007 | 04:22 PM
redrose's Avatar
redrose
most are neither, they're ''vane'' (driven propeller next a stationary prop, several repeats)
Old Oct 15, 2007 | 07:43 PM
93-383's Avatar
93-383
Originally Posted by redrose
most are neither, they're ''vane'' (fixed propeller next a stationary prop, several repeats)
so does that mean that flow rate is pressure dependant. ergo if the fuel system is operated at significantly lower press like for a carb setup can the pump flow more fuel than it does at stock press?
Old Oct 15, 2007 | 08:24 PM
redrose's Avatar
redrose
Originally Posted by 93-383
so does that mean that flow rate is pressure dependant ?
duh, never seen pump curves for a true vaned pump...would guess that perf would be similar to a ''mixed flow'' pump and thus press dependant, but to a lesser deg than centrif
To fuel pump
