Door Lock Problem
Old Oct 18, 2007 | 09:37 PM
54greg's Avatar
54greg
Default Door Lock Problem
My 96 passenger door lock mech makes noise but does not unlock as the driver side does when I approach with the PAS. What the fix? Any DIY pics and procedures? Thanks
Old Oct 18, 2007 | 09:42 PM
geogolf's Avatar
geogolf
Default lock
did you try to work lock by hand 10/12 times[actual lock not with key] then spray some silcone in it
Old Oct 18, 2007 | 09:47 PM
54greg's Avatar
54greg
Good idea! I'll work the lock and lube it and see if it makes a difference. The lock works by hand and with the key currently.
Old Oct 18, 2007 | 10:08 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Might the PKE be set such that it does not open the passenger door?
On our 94, it can be set to either open both doors, or only the driver's door (take a look in your Owners manual).
Old Oct 18, 2007 | 10:42 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
They can be programmed either way. Try unlocking the door with the button. If that works, then you know the door lock is working, and the PKE was just programmed to operate the drivers door. Follow the steps below to make it work on both doors.
PKE Settings
You can use the system for both doors or just the
driver’s door, or you can turn the system off.
Changing the Door Settings
1. Put the ignition key in the ignition, but don’t turn it
on.
2. Press DOOR on the transmitter until the door locks
cycle (about two seconds).
Turning the System Off
1. Take the ignition key out of the ignition.
To turn the system back on, just repeat the steps.
If you are working around your vehicle and keeping
your keys with you, you might want to turn the PKE
system off. If you don’t, the transmitter will keep
locking and unlocking your doors.
To Door Lock Problem
