LS1 in C4?
Old Nov 15, 2001 | 05:38 PM
89BP's Avatar
89BP
Default LS1 in C4?
Has anyone out there done this swap? An LS1 into a C4. There are a lot of these available at very reasonable prices and it sure beats the cost of building up my L98. This would be going into an 89 Auto coupe, but might soon put in a 6spd. I already have a Dana44 with 3.45 gears, and a rebuilt 700R4 with a Protorque 2500 lock up stall converter.
Some questions: 1. will it fit 2. what about accessories 3. what about wiring and ECU 4. transmission/bellhousing fitment issues 5. header and exhaust clearance problems 6. proper radiator 7. smog equipment(making it totally smog legal) And anything else that I missed.
Any help would be greatly appreciated
Jeff Cawthorne
Old Nov 15, 2001 | 05:52 PM
LayZ's Avatar
LayZ
Default Re: LS1 in C4? (89BP)
I can tell you i know it will bolt right in. I would think you would need the wiring harness and computer as well.
Old Nov 15, 2001 | 06:54 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: LS1 in C4? (LayZ)
I was under the impression it wouldnt fit because of the oil pan... its all alum. and shaped funny so it hits the crossmember...
Old Nov 16, 2001 | 12:54 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: LS1 in C4? (BluByU)
There used to be one running at the track, I haven't seen it lately.
Old Nov 16, 2001 | 01:36 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Default Re: LS1 in C4? (Mr Mojo)
If it would fit pysically in all other respects the oil pan would likely have to be a custom job. Not a big deal but not cheap. You would have to bring the whole electronics package over to the c4 (i.e. sensors and ECM). I guess you'd likely lose most of your digidash gauges but I'm not sure there. It sure wouldn't be esier than say... just installing a stroker :)
Cory
Old Nov 16, 2001 | 01:37 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Some guy here had one he was doing on a 84. Had a webpage put up. I remember the oil pan issue, just swapped it out or did some welding. The engine sits differently in the bay, it's a bit higher, so you'll need to get a highrise hood to accomodate the front of the engine.
Old Nov 16, 2001 | 01:55 PM
Cory@LS2PortWorks
St. Jude Donor '09
Default Re: LS1 in C4? (Jeffvette)
Ouch... on the hood issue. $1700 or so from exotic muscle last I heard!
I can't think of a better C4 to use a donor though :)
Cory
To LS1 in C4?
