seat input and thoughts
Old Oct 21, 2007 | 09:39 PM
DerrickC's Avatar
DerrickC
Default seat input and thoughts, update w/ pics
stiil hunting for seats without bottom bolsters that my backside will fit,( and not much luck hunting 94-96 seat) to fit into my 90 c4, without spending 700+ on a4's and sliders.
came across these,
http://www.shophyperformance.com/cgi-bin/hp/001428.html
any thoughts, problems. Is 21" too wide?
thanks,
Derrick
Old Oct 24, 2007 | 02:13 PM
DerrickC's Avatar
DerrickC
update
I have found and purchased a set of black 94-96 seats that look in good condition on EBAY,, and will will update agaionce they arrive and I get them fitted, and see how I fit.
Derrick
Old Oct 24, 2007 | 02:21 PM
Goldcylon's Avatar
Goldcylon
Originally Posted by DerrickC
update
Derrick
Good luck they should bolt right in and will look pretty good. GC
Old Oct 29, 2007 | 07:32 PM
DerrickC's Avatar
DerrickC
Default update w/ pics
GOt me new seats installed today. Bolted right in, far more comfortable but lost about 1.5 inches in heardroom. The 95 seat bottoms are a little thicker and lot firmer than my 90 spot seats.
pics below of my seats and new ride.
IMO the seats are far more comfortable. Has anyone gotten rid of the power tracks and gone with generic sliders? I think that I could gain at least an inch of headroom back.
Also, on the 94 and up, where are the controls for the power lumbar located, was it added into the center console?
thanks for all the help
Derrick
Old Oct 29, 2007 | 07:41 PM
VetteHeadz's Avatar
VetteHeadz
Derrick,
The 94's seat controls are on the center console at least mine are.
Old Oct 29, 2007 | 07:42 PM
DerrickC's Avatar
DerrickC
sorry about the picture sizes above, still learning howthis works.
Shhould be able to view pics at : http://pictures.aol.com/galleries/premed2er
thanks
Derrick
Old Oct 29, 2007 | 07:54 PM
aminnich's Avatar
aminnich
thanks
Derrick
Try signing up for and using a free photobucket account. Here is some info:
http://forums.corvetteforum.com/show....php?t=1336867
Old Oct 30, 2007 | 09:14 PM
Jims1988C4's Avatar
Jims1988C4
I love your Vette Derrick http://i155.photobucket.com/albums/s...Picture010.jpg
Old Oct 30, 2007 | 10:14 PM
Goldcylon's Avatar
Goldcylon
Derrick
Congrats they make a world of difference huh? Yes the controls were moved to the center console
Old Oct 30, 2007 | 10:36 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Yep, that's why we love those 94-96 sport seats. Some of the most comfortable seats in a vette for those of us that are more mature and broader of beam .
Great for those long road trips
Old Oct 30, 2007 | 10:41 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I gotta get a set of those. Any body got a set in gray?
Old Nov 8, 2007 | 06:38 PM
DerrickC's Avatar
DerrickC
Default Seating update and better pictures
First, went to photobucket and signed up, thanks for the suggestion.
so here is a better picture of my coupe
Next, decided to try and lower the seats, so I dont get a concussion ( or more likely damage the interior , hard head...) on every bump. Thought about bolting the seats directly to the floor, but:
Here is what I did.
Pulled the power seat track out, found a manual set of tracks for an early c4 on ebay (about $30 with shipping)
then
1. flattented the rear floor mount bracket
2. shortened /cut the rear seat mounting nut bracket and welded it almost flush against the slide
3. Cut the front floor mount bracket, dropped it 1.75 inches and rewelded it in place.
the only permanent change I had to make to my c4 was to shorten the rear mounting bolts in the floor to clear the lowered slider. I am also going to have to find a new place for the lug wrench. Had more pics, but the are kinda dark ( used my phone)
But, I regained about 1.75 inches of head room (just enough), and kept the funtionality of the seat sliders.
Now if I could figure out how to lengthen the cabin, or shorten my legs just a little.
Old Nov 8, 2007 | 08:58 PM
djpatrick35's Avatar
djpatrick35
I've been looking for a 94-96 set of seats myself for my ZR-1 because of my size (6'6-295) BUT do they really sit higher?
In terms of height, I sit perfectly now but I don't think I could afford a few more inches. This scares me because if I'm in the car for more than 1-2 hours in a row my *** KILLS me! But if I'm going to hit my head on the top for every bump, that's not going to help me either!
Old Nov 8, 2007 | 11:36 PM
DerrickC's Avatar
DerrickC
The seat bottoms are thicker and firmer than the 90 sport seats.
As I noted before, I am also 6'6" and the fit is tight no matter what you do, but with the current set up I am much more comfortable.
Derrick
Old Nov 9, 2007 | 12:18 AM
Goldcylon's Avatar
Goldcylon
No its a matter of how compressed the seat foam is. Newer foam you ride higher. You get a little more clearance out of a glass targa as well!!
Old Nov 9, 2007 | 04:56 PM
RandyJ75's Avatar
RandyJ75
Here is what I did.
then
Derrick,
I also have a '90, and I just got a set of cushions off of Ebay, but I need the seat frames, as the '90's will not work. Does this mod have any affect on the seat functions? Did you change the controls on the console to the '94 style? Anything else I should be aware of? I will also need to use the lower seat tracks, as I am 6'4". They are from a '84, correct?
Thanks for your help.
Randy
Old Nov 9, 2007 | 05:30 PM
CSS996's Avatar
CSS996
Too bad they didn't have Ruby interiors in the later cars...:o
But I am kinda digging the support of the seats in my '93. Even though I could use another inch or two for my fat azz.
To seat input and thoughts
Old Nov 9, 2007 | 06:56 PM
RandyJ75's Avatar
RandyJ75
I am sure that you could get some newer seats covered in the correct color by Al Koch
Old Nov 11, 2007 | 02:37 AM
DerrickC's Avatar
DerrickC
Randy,
the mod should have no effect directly on the seat function, you do loose the power functions when you loose the taller, power seat base.
The rest of the seat functions should work the same, as they are housed in the seat base itself. I have not changed over to the 94 style console controls yet, but plan to, in order to regain the power lumbar function of my 94 seats. Not sure if this helps, in near the end of a 24 hour shift, I tend to ramble.
Derrick
Old Nov 11, 2007 | 09:43 AM
RandyJ75's Avatar
RandyJ75
Randy,
Derrick
Thanks, Derrick
