tires
Old Nov 16, 2001 | 12:25 PM
Jim D's Avatar
Jim D
Default tires
I know this is a dumb question, but I have a 93 and have stock wheels 8.5 fr-9.5 rear can I put 9.5 all the awy around and do the tires have to be directional
like the GSC I have in now. Thanks Jim
Old Nov 16, 2001 | 04:26 PM
Mikez40's Avatar
Mikez40
Default Re: tires (Jim D)
Yes, you can put 9.5x17 all the way around. In fact that is how the 92' comes. Also the Z07 option on the 93' comes with 9.5 all around with 275/40/17 tires.
No you do not have to have directional like the GSC. But I believe most high preformace tires with "Z" rating are dirctional. Go to tirerack.com and they will
list all the tires for your year vette.
Old Nov 17, 2001 | 11:44 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: tires (Mikez40)
If you're going to change rims...9.5s will definitely fit on the front allowing you to go with 285/40s all around so you can rotate. You'll notice a definite difference in the handling! Also consider putting 11s on the back for 315/35s. You won't be able to rotate fromt to back...but i've never needed to.
Those changes without a doubt the biggest SOP difference in the handling of the 94.
So far as the tires go...many ARE directional...but many are not. My preference is Michelin, and they're not.
[Modified by Alchemist, 9:46 AM 11/17/2001]
Old Nov 17, 2001 | 11:47 AM
AS84's Avatar
AS84
I couldn't find any GSC's when I replaced mine a week ago. I heard they were discontinued. I went with the F1's and I really like them. But they too are directional.
Old Nov 18, 2001 | 09:30 PM
95Purple's Avatar
95Purple
Default Re: tires (AS84)
So how far will 315/35s on 11" rims stick out of the wheel well? :D
Old Nov 18, 2001 | 10:05 PM
cvette's Avatar
cvette
From: I've been going to this school for 7 years, I'm no dummy!
Default Re: tires (95Purple)
Anywhere from a half an inch to a little over an inch. Don't know why it varries but it does.
Old Nov 18, 2001 | 10:33 PM
95Purple's Avatar
95Purple
Default Re: tires (cvette)
Thanks guess I will go with the 18x9.5 with 285/35zr18 :crazy: half to an inch sticking out, dont think I would like that look.
Old Nov 19, 2001 | 12:37 AM
Bill Reid's Avatar
Bill Reid
11" rims sticking out of the fender isn't that bad of a look... BUT... you can reduce that by putting a little negative camber into the rear wheels... say a 1/2 degree. Works for me :D
Old Nov 19, 2001 | 12:01 PM
95Purple's Avatar
95Purple
Default Re: tires (billreid1@home.com)
Looks great, they dont stick out at all. What size tires do you have on the rear? :D
To tires
