From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Vibration at 74mph?
It is not in the wheels or tires. I have had two sets of wheels and three sets of tires on it. Every time I am on the interstate and hit about 74 the car shakes really bad...
It has been wrecked before and the frame is a little bent(~1/4in). Could that cause it?
Also it has been aligned two times at different shops...
Yes it could be especially if you have ruled out both the tires and the wheels. But I would also have a look at the Half shafts and the Drive Shaft.
Originally Posted by hmcquade
In the wheels did you mean rotors? I have an 84 and had to get my front rotors turned.
Hugh
The rotors and pads are both somewhat new... I just can't rember if it was doing it before the new rotors. They were replaced while I was reparing it after the wreck. So I don't know if the wreck or rotors caused the vibration...
I will switch them around and see if that fixes it
Check your shocks. Had a bad vibration at high speed, replaced two front shocks (they were broken) and vibration went away.
Just giving you a hard time! I agree that the shocks could be causing some wheel hop that can cause some strange vibrations. Be sure and check tie rods as well.
A bad front wheel bearing caused vibration on my wifes '86.
Edit: after changing both front bearings.... I'm going to have to change the rears too.
During the test drive I still had just a bit of bounce on the left front... right rear is a bit loose after finally getting it up in the air and giving it a shake.
Reason: right rear
Most likely you have a bad u-joint in the driveshaft and/or the axle shafts. There are six of them that can go bad. I doubt the accident has anything to do with it.
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Replacing the u-joints on my half shafts got rid of a minor vibration over 65 on my '88.
Originally Posted by MyOtherCar
uhmmm,, drive at 73, ...or 75????
j/k
Originally Posted by MotorCity_87_C4
Mine had less then 10k on them but were cheep no name brand.
I got KYB's... I don't think it is the problem
Originally Posted by Andrew
Hey, isn't 74 mph over the speed limit?
Will do
Originally Posted by Mr. Peabody
If you take it up to say 80 does it get better or worse?
Also when you took it to the alignment shops, did they say that they were able to align it? I presume that you had a 4-wheel alignment done?
It gets worse, all the way up to top speed it never lets up. And yes, it was a 4 wheel.
