Electronic spark Control
Old Oct 27, 2007 | 12:49 PM
revival1's Avatar
revival1
Default Electronic spark Control
I have a problem with my 1989 corvette. If I start the car and turn it off right after I start it. It won't start till I let it sit for a while. I was told @ a local shop that this was due to the Electron spark Control. The module in the distributor has been replace and he's done all the other tests. Is this possible?
Thanks in Advance,
Lori
Old Oct 27, 2007 | 01:47 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thanks in Advance,
Lori
No. The electronic spark control (ESC) is a completely different part of the vehicle electronics from the electronic spark timing (EST) distributor module. They both interface with the computer (ECM), but that is all they have for common. The ESC is merely a knock/noise monitoring circuit that informs the computer when knock is occuring. The computer then decides if it wants to listen to the advice of the ESC. Regardless, the ESC is disabled by software during cranking and idle conditions.
Old Oct 27, 2007 | 05:48 PM
revival1's Avatar
revival1
OK thanks foe the reply. When the tech sprayed started fuild in the PVC it started right up. Can this help with what the problem is.
Thanks in Advance,
Lori
Old Oct 29, 2007 | 06:26 PM
badabing9's Avatar
badabing9
To Electronic spark Control
