Normal Oil Pressure?
Old Oct 27, 2007 | 06:59 PM
armybyrd's Avatar
armybyrd
Default Normal Oil Pressure?
While normal driving what should my L98's oil pressure be at??
Old Oct 27, 2007 | 08:05 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
This should be good.
Mine ("85) rarely dips below 60, and on average at cruising speed, is 66-72.
I've seen it as high as 80, never below 40 at idle.
96K miles, all original lower end, valve seals replaced 6 years ago.
Old Oct 27, 2007 | 08:27 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default oil pressure.
In my opionin, 20 psi at idle would be ok. That would be the lowest. Mine is around 40 at idle, 55 driving. Just my .02
Old Oct 27, 2007 | 08:44 PM
armybyrd's Avatar
armybyrd
Mines at around 22psi while driving.
Is that too low?
Old Oct 27, 2007 | 10:04 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
That does seem about 25psi less than I would have expected.
At cold start my '88 L98 (122k miles) is upper 60s for the first few minutes. After fast idle is over it's in the low 40s at idle (750rpm +/-).
At 2k rpm and 70mph at operating temp, it's in the mid 50psi range.
I have seen it as low as 22psi @ idle on an upper 90* day stuck in traffic with engine temps in the standard fan switch range (215-228*).
Oil temps are usually about 10-15* higher than coolant temps.
I don't know if this helps, but there you have it.
Old Oct 27, 2007 | 10:19 PM
Chapindad's Avatar
Chapindad
Is that too low?
That us too low. Check your oil, you are probably a quart low.
To Normal Oil Pressure?
