I think those rears are a +59 offset with a 19x10 wheel. They will fit completely inside the wheel well. I have 18x11's with the same offset and they sit totally inside the wheel well. Front is probably a 18x8.5 with a +48 offset so it should sit just right up front. Post pics if you pick these up.
It includes the TPMS....will it work on my C4...will I need adaptors?
Hi the front will fit on the c4 as there the same 56mm offset but the backs will NOT the 19"x10"s from a c6 z51 are 79mm offset and will hit the tops at the control arms you will need 1 inch wheel adaprters ,, but everyone one is telling me to use the 1.25 spacers but i think it will bring the wheels outside the wheel wells
i have these same wheels onmy c4 that your trying to install on yours and i now the backs hit as i drove the car with them on and cut in to the back of the tires but ordered the 1 inch wheel adapters and will tell you how it comes out
oh yes the wheel senser system will STILL WORK it does in my 90 with the new c6 sensers
