Antenna
Old Oct 31, 2007 | 11:13 AM
Corvettewolf's Avatar
Corvettewolf
Default Antenna
As usual, on C4s, the antenna on my 94 sticks when going up or down. I do not use the radio and only play CDs. What is the easiest way to keep it in the down position?
Old Oct 31, 2007 | 11:36 AM
4DSZR1's Avatar
4DSZR1
If you look up from underneath the antenna, you'll see it's somewhat easy to get to. If there's a plug to the up and down power mechanism, un-plug it. If not......................you could cut the wires and protect the ends or install plugs.
Have you tried putting a little silicone on a rag and wiping the antenna while its extended?
Old Oct 31, 2007 | 11:55 AM
RRT vette's Avatar
RRT vette
unplug it.
Old Nov 3, 2007 | 02:00 PM
03blackburb's Avatar
03blackburb
The antenna onm my 94 does not fully compress, it fully extends but goes down and stops leaving about 10 inches still extended. If I pull the antenna and then genlty push it down, it will completely collapse. The next time I turn the radio on and then off it extends and retracts leaving about 10 inches still out.
I pulled the mast and ribbon cable expecting to have to replace the unit but the cable is not missing any teeth nor is it broken. The motor seems to be working fine.
Is there a way to "reset" the downward travel length for the motor?
Old Nov 3, 2007 | 09:55 PM
crollr's Avatar
crollr
I have a 92 convertible. I unplugged the connector under the carpet of the rear cargo area, over the wheel well, on the drivers side. Not sure on the coupe. If I recall, I think there may have been 2 connectors there. They were quite large and had more connections than I would have expected.
Old Nov 3, 2007 | 10:03 PM
crollr's Avatar
crollr
For 03blackburb, some of the cable could be broken and stuck in the motor. That is the issue with mine. It did the same thing you are describing. The motor would have to come out, to get the broken cable part out, before new antenna could be installed. I decided just to diconnect it. It looks better without the antenna sticking up any, IMO. Still gets some local stations if needed.
Old Nov 3, 2007 | 10:49 PM
03blackburb
I pulled the motor and checked it, it is the model that is GLUED together. Is there any way to tell ifthere is a broken piece of cable sutck in the motor?
If it push the mast down, or pull then push down it WILL go all the way down. THen when turing on the radio or car, it does extend out completely.
I have also wiped the mast sections off and added a few drops of clean lube.
Old Nov 3, 2007 | 11:07 PM
crollr's Avatar
crollr
I bought a replacement mast, and the instructions said that when you pull the old mast out, make sure the cable of the old one is the same length as the new one. If it's not, then some is still in the motor, and will have to be removed before installing the new one. Mine was short, so I'm assuming some is still in there, but I have not taken it out to confirm. The exposed part of the cable of the new one is 36.5 inches long, that is the exposed part of the cable, outside the mast. Hope that helps.
Old Nov 4, 2007 | 12:52 AM
Arkybill's Avatar
Arkybill
I've got a 94 LT1 that the antenna doesn't go all the way down. I've asked this question several times and haven't gotten an answer. I've got the replacement mast sitting on the counter in the shop. The shop manual and the directions that come with the replacement mast say to remove the old antenna.
Only problem is, the old antenna has the same little collar the new antenna has. It holds the antenna body from coming out of the housing. My question is-- do you just pull the old mast out and hope the collar all comes out, or do you smash the old mast and then try to get the collar out?
The directions say to "gently pull the old mast out". Well, the old collar ain't gonna come out gently.
Any help or advice will be greatly appreciated.
bill
Old Nov 4, 2007 | 01:34 AM
schrade's Avatar
schrade
I got the '94, 'last 4" don't retract too unless helped', and am gonna' pull this thing to replace this week.
First time was exploratory; without disassemblin' the motor (some pics posted)...
http://www.corvetteforums.com/m_4217..._1/key_/tm.htm
03 - just glue? If it's toast, how come you didn't try to break it down?
Old Nov 4, 2007 | 08:52 AM
crollr's Avatar
crollr
The replacement antenna I got came with a little tool to remove the mounting nut that holds the antenna in place. There are two flat spots on the mounting nut for grip, if you are going to try and use your own tools. I wouldn't muscle it.
Old Nov 4, 2007 | 11:45 AM
03blackburb
Does anyone have a length measurement of a new replacement mast and ribbon cable?
Old Nov 4, 2007 | 08:00 PM
crollr's Avatar
crollr
46.75 inches
Old Nov 4, 2007 | 09:28 PM
03blackburb
Thanks. I will pull it again tomorrow and measure.
Old Nov 6, 2007 | 11:41 PM
03blackburb
Well. I measured and measured again. Total length on my mast and ribbon cavle is 46.75 inches.
The cable is clean and the mast sections are clean and not sticking.
Any other ideas?
Old Nov 7, 2007 | 05:10 AM
fc_soldier's Avatar
fc_soldier
Well it depends my sticks in the winter. Is it cold where your at? Take sometime to fill out your profile so this can be easier for the next person.
Old Nov 7, 2007 | 09:25 AM
03blackburb
The antenna has been not been going down since I have had her, year and a half.
As for temps, summers over 100 and winters get cold with a few days with lows in the 30's. Temps don't seem to be a problem.
To Antenna
