Chimes
Old Nov 5, 2007 | 05:38 PM
BobRR3's Avatar
BobRR3
Default Chimes
Quick question. all the interior warning lights work. seat belt, door ajar, key in ignition, etc. However, the chimes for the door and seat belt don't work. I manually checked the CCM by grounding pin #12 and then going thru the manual check procedue and the chime generator works. Both chimes work. The seatbelt light works but the chime doesn't. I don't understand because there is only one seatbelt switch ??? i'm confused.
