Fuel Line Problem 1986
Old Nov 7, 2007 | 07:53 PM
mikkky's Avatar
mikkky
3rd Gear
Default Fuel Line Problem 1986
The Neopreme Fuel Lines That Come Off The The Steel Fuel Lines Has Dry Rotted, These Small Pieces Of Neopreme Hose Were Compressed On Similar To A Hyraulic Lines, Unfortunitly They Are No Longer Available. How Can I Make A Repair Since There Is Approx. 60 Lbs Of Pressure, I'm Told A Standard Hose Clamp Will Not Work. Help Me I'd Like To Drive My Car Again.
Old Nov 8, 2007 | 09:44 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '25
I'm not sure about this but these guys make hydraulic lines to order so I'll list their digits & web addy.....check'em out maybe they can help ya.
www.ormebros.com
1-818-885-1414
Good luck
Old Nov 8, 2007 | 11:05 AM
Muffin's Avatar
Muffin
Have you looked at having braided stainless put in to replace the rubber? Thats my plan for this winter.
Old Dec 4, 2007 | 08:26 PM
loaded vet's Avatar
loaded vet
Default Just finished mine
You may what to take a look in the C4 Tech/Perf section. I posted a thread with some pictures of what I did to correct this broblem a couple os weeks ago.
You can search for loaded vet or engine fires a fix? in the C4 Tech/Perf area. Should there be questions let met me know.
GN
Thought I would add a link to photos of the course I chose to correct this danger.
http://s239.photobucket.com/albums/ff207/gwnewlon/
Last edited by loaded vet; Dec 5, 2007 at 09:22 AM. Reason: Provide easier link to photos so that more have a better idea of the risk.
Old Dec 4, 2007 | 08:37 PM
Bob CTS's Avatar
Bob CTS
The fuel line at the top of the tank uses hose clamps, just remove the bad section and replace with top quality hose, I would use two clamps for redundancy, maybe even flare the line a bit to keep it from possibly popping off. Where are you located as I have the entire fuel line for a 86, could never find a box to ship it, way to awkward.
To Fuel Line Problem 1986
