it's been a while, but I need help again
I have been fortunate enough for the last several months to not have to post any questions about my '93 coupe (142,000 miles).
A while back, it seemed everything went wrong on it all at once (transmission rebuild, new tires, cooling fans, u-joints, serp. belt, etc...) all within a month of each other. Since then, things have been pretty calm. Aside from an overheating problem, which was remedied by installing a new thermostat, radiator cap, coolant system flush, and temp sensor, I haven't had to complain much.
However, for the last few weeks something has been acting up occasionaly.....
One afternoon, I went to leave work for the day, started the car, and the idle was very rough, and it kept wanting to die. There was a strong smell of exhaust coming from the engine compartment, and if I gave it some gas, the roughness went away and seemed to respond normally. But as soon as I let off the gas, it would choke down and would die if I didn't give it gas. Well after about 10 minutes of sitting there playing with the gas pedal, the idle was still rough, but it would continue running on it's own. So I left and drove home, and going down the road if I punched the gas, it responded perfectly, but when I stopped at a light, the idle was still a little rough.
Parked it for the night, and fire it up the next morning with no problems at all. It ran fine for about a week or so, and then it did the same thing again, only without the strong exhaust smell. It has done this 3 or 4 times over the last few weeks, but seems to just do it once, and then go away for 5 or 6 days. Tonight it did it and I had my headlights on, and when it started to choke out and want to die, my headlights would dim, and as I hit the gas to keep it alive, the lights would go bright again.
Where should I start?
-Plugs and wires were changed about 2 years ago..
-injectors have never been changed since I've had it (91k miles-142000 currently)
Thanks.
Adam
They scanned it and said that the opti was throwing a code, but by then, it stopped acting up, and they couldn't duplicate the problem. They were going to leave it hooked up to the computer overnight to see if they could pinpoint anything else or at least verify that the opti is bad.
If so, am I ok to just get a replacement from autozone or somewhere similar for $150 and have them put it in? I've seen people talk over the last few years on the forum about expecting to pay over $1000 to replace the opti? is it really that much labor? Should I or can I get the newer opti that is redesigned from my 93's model that is less prone to water damage?
I've had the car for a little over 3 years, and it has 142k miles, and I haven't replaced the water pump, and don't have any records of it being done before I got it, so I should probably change out the water pump while they're at it just to be safe right?
I guess I'll find out tomorrow what they say at the shop....
Thanks for your input.
Adam
It was indicating it was cold and sending f to much fuel .
$15 part.$40 for the diagnostics.
Good luck
