The SBC ID guidebook I have lists the 3998993 head casting as a 1968-76 350ci head with 1.72/1.50 in. valves used in trucks. This book was printed 1996. The J182 is a casting date code & means Oct 18th, 1962, '72, '82, '92 or '02 (they didn't get real specific with the year. TPA was not listed but TPB & TPC were used for 307ci engines in '72 for vans and buses. GM re-used some of these 3-letter "engine intended use" codes repeatedly so it may mean something different in later years-I'd sure hope so. To my knowledge, GM didn't re-use the head casting numbers. I think they are actual GM part numbers in their engineering system and are unique to a particular casting. Hope it helps.
