Hey guys i m in the process of changing the water pump, and the opti, plugs & wires on my 93. Would it be a good idea to go ahead and change the thermostat too? Also i have read alot of post on the 180 or 190 thermostat which one did it come with from the factory? also whats the pros and cons for each? Thanks guys!
I would, it just makes sense to do so and the cost is minimal. A lot of debate on which heat range to use. If I was to choose the 180 would be fine for me vs. the 195. It’s a matter of where you located geographically. 195 if you get snow and like the heater to work sooner or the 160 you don’t get any snow and don’t need heat. GC
