Hatch drain tubes
Old Nov 10, 2007 | 03:45 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Hatch drain tubes
I read on here that it is one of the best mods you can do to a coupe. So I bought some, and read the instructions, and read the archives on here on how to do it. So I went and tried to do it. But the instructions said you would drill through two layers of fiberglass. I went down one and hit steel. What did I do wrong or is the instructions wrong. This is a 94
Old Nov 10, 2007 | 03:56 PM
C4DERF's Avatar
C4DERF
I just tried ithe sane thing last weekend but I didn't hinkt to post about it till I saw nowhere Man's post. ANy ideas fellow CFers?
Old Nov 10, 2007 | 04:39 PM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
I would never do it.
Old Nov 10, 2007 | 05:21 PM
c4cruiser's Avatar
c4cruiser
At what angle did you hold the drill? IIRC, the drill has to be angled towards you (the drill is away from you with the bit pointing towards you) when drilling so that the drill won't go into the cabin.
If you remove the rear inner fender liners, you should be able to see hos the drain will line up as you drill down. The tube should exit into the fenderwell.
Old Nov 10, 2007 | 05:27 PM
Wayne88's Avatar
Wayne88
I did it a few years ago.
I first used a narrow bit for a guide hole. I drilled very cautiously on a slight angle away from me. It went thru 2 layers. Then I used the recommended size bit.
Also, I did this when I changed my targa weatherstrip.
Old Nov 10, 2007 | 05:30 PM
Nowhere Man
I drilled liked you discribed
Old Nov 10, 2007 | 05:57 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Old Nov 10, 2007 | 06:00 PM
ynk1121's Avatar
ynk1121
Be careful what you drill into. There is a wiring harness there and someone posted pics a while back of what one looks like when a drill goes through it.
Old Nov 10, 2007 | 06:06 PM
All2kool's Avatar
All2kool
What part of drilling holes in the car doesn't scare you?
Old Nov 10, 2007 | 06:15 PM
Nowhere Man
I hate the thought of drilling or cutting holes into my car too. but I really hate it after you wash and detail the car, and you close the glass water goes every where. and plus my dads 91 vert has a drain holes in top door. and they seem to work very well.
Old Nov 10, 2007 | 06:24 PM
All2kool's Avatar
All2kool
I just push the water from one side to other a couple of times with a towel - works like a charm really.
Old Nov 10, 2007 | 06:37 PM
Andrew's Avatar
Andrew
I just make a cone shape out of a paper towel, stuff it in each corner, dry the rest of the car, and by the time I'm done, it pulls the water out. Works like a charm, but those drain plugs would be nice. I'm just to much of a chicken for that one!
Old Nov 10, 2007 | 07:49 PM
vetteboy88's Avatar
vetteboy88
I use an electric leaf blower to dry the whole car. I never touch it with a drying cloth. The leaf blower gets you some strange looks from the neighbors, but there is nothing like getting all the water out of the mirrors, rims, hatch area, etc.
Old Nov 10, 2007 | 07:52 PM
The Gooch's Avatar
The Gooch
Not a lot since I build my own race cars, but this particular process on my original car...I'd never do it.
Old Nov 10, 2007 | 07:53 PM
The Gooch's Avatar
The Gooch
Old Nov 10, 2007 | 09:18 PM
Andrew's Avatar
Andrew
I bet you do get some strange looks! That is a good idea. Never would have thought about that, but it is the same idea as many of the touchless car washes uses. I'll have to try that.
Old Nov 10, 2007 | 10:40 PM
Motsiv2's Avatar
Motsiv2
I have good luck with and ear dropper. It sucks the water out.
To Hatch drain tubes
Old Nov 10, 2007 | 10:46 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I would never drill holes. If it rains the car gets wet. If I'm washung the car when i finish drying the outside I take a 3' piece of 1/4" plastic tubing and syphon the water out of the corners. The tube also come in handy for syphining the water out of the hood latches.
Old Nov 10, 2007 | 11:13 PM
ynk1121's Avatar
ynk1121
Originally Posted by JrRifleCoach
That's the pic. I bet someone was kicking themself after that one.
Old Nov 10, 2007 | 11:48 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
I use a turkey baster to suck out the water
