help with door removal
Old Nov 12, 2007 | 09:40 AM
t-93's Avatar
t-93
Default help with door removal
can anyone tell me the best way to unhook the wiring going into the door? there is a big bundle that controls the windows and locks and etc.. Is there a connector just inside the dash that will disconnect the entire bundle? or do I have to do something else? Thanks for your help. In case your wondering....I am painting the car and need to remove the doors to paint the jams.
Old Nov 12, 2007 | 06:55 PM
Red Dwarf's Avatar
Red Dwarf
I think it would be easier to remove the door panel (s) & fish the harness (s) thru the door. I imagine that the wiring going thru the door to the dash go directly to each component & would be very tough to pull thru the A pillar opening & you would also have to remove the lower trim panel, etc. Maybe some else has some thoughts?
Old Nov 13, 2007 | 09:18 AM
t-93's Avatar
t-93
I have the panel off, but thought there might be some easy trick to disconnecting them.
To help with door removal
