Scanner results vs. code reading
This is some new test data I gathered this morning on my "new" 90 Z to test the scanner s/w upgrade, and get my first peek at what is really going on in my "new" ride.
This table shows 37 different measurements recorded and arranged in columns separated by 1 second time intervals. You can see at a glance what was going on and when. One of the surprises is O2 sensor cross counts; the left is higher than the right sensor. That may not be a problem at the current level, but something to keep an eye on in the future - especially if it starts running rough and reverts to "open loop" operation!
Beats the hell outta a alligator clips and "dash diving", huh?
FWIW,
P.
The scanner will gather and interpret codes, clear codes, monitor a single sensor real-time, snapshot all (37 for the '90 OBD-I "Z") measurements, and monitor/catalog real-time all measurements and update until the user triggers and event where the scanner saves the previous 14 seconds and records the next 14 or so.
The EZ-PC software will display the table you see, and also graph any single or several of the measurements for a visual comparison (e.g. throttle opening vs. O2 sensor results, etc). And, the s/w will access the internet for firmware/software updates and downloads. The data will export into Excel, for example (what you're looking at is an Excel spreadsheet w/imported data), in case you want to do some custom graphs or whatever.
Of course this is "ho hum" to many on this board and tuners especially. But, I remember the level of frustration I had with a couple of mechanics I has the "pleasure" of dealing with when I bought my '95 Vette. I went thru the "dash diving" ALDL routine, trying to figure out what was going wrong. But, the problem (that time) was intermittent and it wouldn't throw any codes.
Buying the scanner was like walking out of a cave into the sunlight! It was the best single tool I ever bought for my Vette. I often see folks asking what this or that code means or see recommendations to short this or that ALDL pin...makes me cringe. (Not to put down using a simple paper clip and a code table to see what codes are thrown. When it works it works!...But, that method is like looking at the heavens thru a long straw!
)If one sees an AutoXray EZ Link 1000 on Ebay (or whatever), with updated s/w it will work on our C4s thru 95 (with the OBD-II cable for the '95 - available from AutoXray), and would be worth every penny! If you have a 96, then you will need one of the newer scanners, or a laptop with a package on it that accommodates OBD-II.
Hope this helps!
P.
P.
I use PCMFORLESS and TunerCat for tuning.
